The lights on the exterior of the camper, turn signals, brakes and running lights all work from your TV. This is a separate circuit from the pup battery and are fused on the TV, not the pup. The fuse holder on the pup from the battery is for the interior lights, water heater, water pump, refer, furnace, and scare light on the side of the camper. Your lights, furnace, water heater and water pump work on 12 volts even if you are plugged in to a pedestal or generator. So does the refer if you are propane. You have a electrical problem with the 12 volt operated parts.
Richard & Jill
