04-26-2018, 12:14 AM
Is my awning backwards?
A while back I bought a screen house for my dometic awning that has zippers on it. My bag is black with no lettering on it, while I was out last time I found the words dometic in white facing the roof... Is it backwards? Now I've seen pics with the words facing out. I want to make sure it's on there correctly before I go and install the screen house.
Rockwood Premier 2516G
2016 F150
04-26-2018, 05:29 AM
NH Maple Maker
Is the colored side up and the white side down when it's opened up? If the awning is oriented correctly someone at the factory put it in the bag wrong.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
04-26-2018, 08:16 AM
I'm trying to remember..I'll have to go and open the bag. I know that the zipper on the sides are facing up and you can't see them when the awning is open. Also one thing that made me think is the flap at the end of the awning is on the inside of the support that the side supports fold into, ive always seen awning with that flap on the outside to cover the support from view.
2016 F150
04-26-2018, 06:10 PM
NH Maple Maker
I think it was installed backwards. The flap should be outside covering the support that the side supports fold into.
Russ
04-26-2018, 06:34 PM
Location: Alberta - East of the Rockies, West of the Rest
Also, if the awning is hemmed along the edges the seam should be facing down not up.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
04-26-2018, 06:37 PM
I'm going to open the bag on Saturday and take more pics to share plus look at all the suggestion s since I can't remember what I should lol.
2016 F150
04-26-2018, 07:17 PM
You see what I mean when you zoom in.
Ordered: 2021....
04-26-2018, 07:36 PM
Yeah I do see that. This is the only pic I have if the awning open. You can see the flap at the end goes to the inside of mine.
2016 F150
04-28-2018, 06:09 AM
Here are a couple pics of what mine looks like on my 2016 Rockwood Premier 2516g.
04-28-2018, 07:44 AM
Yeah I do see that. This is the only pic I have if the awning open. You can see the flap at the end goes to the inside of mine. Attachment 169634
Hard to really see with that pic, small pic and from a distance. If the support bracket and legs cause the "top" to wrap around and over the bracket then it's upside down. What I mean is if you unroll the awning all the way with the legs still inside the bracket and that bracket is on the top size of the awning then it's upside down. If it's on the bottom when unrolled then it's not upside down.
Relatively easy fix if it is upside down.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
04-28-2018, 07:50 AM
A while back I bought a screen house for my dometic awning that has zippers on it. My bag is black with no lettering on it, while I was out last time I found the words dometic in white facing the roof... Is it backwards? Now I've seen pics with the words facing out. I want to make sure it's on there correctly before I go and install the screen house. Attachment 169589
Is the underside of the awning white ???
