Originally Posted by rsdata
I seriously doubt the dealer will know what converter you have... <<SNIP>>
high end charger or not, pop the tops (use a flat blade screwdriver and pry them off) off the battery and look at the liquid level with a flashlight... <<SNIP>>
To the OP: This is good advice.
Perhaps you have an owner's manual? It might only be a two-sided sheet included in the package supplied by the manufacturer/dealer.
RUMOR HAS IT that the common WFCO brand converters installed by the manufacturer are not as good as other brands. Search threads on charge controllers if you'd like to investigate opinions on this subject.
As for the battery needing distilled water, this is VERY important. Individual experiences vary, with the more savvy folks using disconnect switches and other tactics to manage the battery with less charging.
With my solar kit, I keep a close eye on the electrolyte level in the battery, and I find that I need to top it off about every 4 to 6 weeks during the summer. I suspect that, between the routine weekly use of the converter to prep for a trip and chill the fridge, occasional use on the generator, and the relentless supply from the solar system managed pretty well by the charge controller, this accounts for the need to top off with distilled water on a regular basis. Measured in "turkey basters", I regularly need to add about .75 turkey baster to each cell. That's several ounces - quite a bit.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at
Lake Vallecito.
