Old 05-24-2019, 09:59 AM   #1
JasonRW1910ESP's Avatar
Leveling side to side
This may be a stupid question but itís my first pop up. We were doing a trial run of setting up in the yard and the camper wasnít level side to side. I pulled it up on blocks on the low side and it still wasnít level. I raised the jack to get it off the hitch and lowered the stabilizer jacks but the camper was very shaky and didnít feel comfortable setting it up all the way. Any suggestions on setting up on unlevel ground?
JasonRW1910ESP is offline   Reply With Quote
Old 05-24-2019, 10:06 AM   #2
I've never had a pop up, but I think the kinematics are the same. If you were setting up in the lawn, the weight of the trailer may have pushed the leveling blocks into the grass which would make it difficult to level anyways... When you're in a site or dry camping, you'll typically find solid ground to level off on. That will make it easier. The same goes for the stabilizing jacks, if they went into grass, the weight of the trailer will most likely push into the grass making in not as stable. Hope that helps a bit. Enjoy your camper!!
2017 Chevy Silverado 1500 LT/Z71/4X4/3.42 gears
2019 Palomino Puma 27RBQC
Infinite_Enigma32 is offline   Reply With Quote
Old 05-24-2019, 10:08 AM   #3
That make sense. Thanks for the input
Old 05-24-2019, 10:15 AM   #4
Always Learning
Put more blocks down until you're level.
Check your owner's manual to see which order you should do next (stabilizers then roof or roof then stabilizers). Use the stabilizers to snug it up a bit.
There will always be some movement, but it shouldn't feel unsafe.
http://learntorv.com/rv-leveling-is-...uick-and-easy/
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
ependydad is online now   Reply With Quote
Old 05-24-2019, 12:30 PM   #5
I stick on a calibrated level (bought at Walmart) on the front of the A-frame or PUP. The calibrated level gives me a good starting point for number of orange blocks (Lynx Levelers) needed to level side-to-side. I back onto the blocks, check the level again.
Then I chock the wheels and detach the tow vehicle (I use a WDH so several steps there). Once the TV is out of the way, I level front-to-back with the tongue jack. I use a 2ft carpenter's level on the latched roof to get it level.
Next step is to set up the pop-up or A-frame. I do NOT put the stabilizers down until AFTER I have the roof and sides up, and the beds pulled out on a pop-up. The reason for this is the frame and box on A-frames and PUPs are not as rigid as on TTs with full roof and sides. Putting the stabs down first sometimes/usually introduces subtle twists in the frame which cause the door and canvas not to fit properly, or in the case of an A-frame, the roof latches not to line up properly. Even when I just kiss the ground with the stabilizers, I've sometimes had issues with setting up with stabs down.
Pulling the stabs up before folding the camper helps me to not forget them before I drive off. Been there, done that, bent the stabilizer. Stabs down also makes it a lot harder to get the WDH bars on.
just our experiences, continuing to learn
Fred W
2 Pop-ups, 2 A-frames
Old 05-24-2019, 12:36 PM   #6
Thanks for the info, every little bit helps.
Old 05-24-2019, 12:57 PM   #7
Invest in a BAL Single Wheel leveler, worth it’s weight in gold.
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 05-24-2019, 01:31 PM   #8
njfishing's Avatar
First of all never use your stabilizer jacks to level the pop up... They are meant to stabilize it from rocking side to side or back and forth when you walk around inside the pup.
So here's the drill.... While you're hooked up to your tow vehicle, the first order of business is to get it level side to side. You don't have to worry about front to back since once you get the trailer off your tow vehicle, you'll use the tongue jack to do that...
Depending how low the one side is I'll take a stack of these leveling blocks and drive the low end tire up on them until I get it level... Important to note if its very low on one side I usually try moving to somewhat lever ground.
Now that you have it level side to side, chock your pop up wheels, one in the front of the tire and one in the back and unhitch from you tow vehicle....
Next order of business it to level it front to back by raising or lowering your tongue jack...
Now that you're all level, lower your stabilizer jacks so they're good and snug. If it's soggy underneath them you can put one of the leveling blocks under it to spread the load...
Go into the trailer and walk around a little bit.... I will say that your going to get a little bouncing which is normal and usually is more noticeable when people are bouncing around in the beds or entering the pup on the steps, but it should not feel unsafe, you'll just get some shake.
Hope this helps and remember do not use the stabilizer jack to level... Level first, then use the stabilizer jacks...
Name:	RV leveling blocks.JPG
Gerry Z
2018 Forest River Heritage Glen 272RL
Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
njfishing is offline   Reply With Quote
Old 05-24-2019, 01:32 PM   #9
Originally Posted by JP Camper View Post
Invest in a BAL Single Wheel leveler, worth itís weight in gold.
X2 ... there are certainly many ways to get level, but for a single axle trailer, the BAL is about the easiest way to go, ... used one on our 17ft Casita, and liked it so much, when we moved up to a dual axle 21ft Micro Lite 21DS, I bought another one and used THEM on the new 21DS, ... worked great, but that weight trailer was just about the limit of what the BAL's could handle, ... so, when we got the Micro Lite 25KS, I had to abandon the BAL's and go to something more conventional, ... hello Andersen Leveler .....
fella10 is online now   Reply With Quote
Old 05-24-2019, 01:38 PM   #10
njfishing's Avatar
One more tip for you... I you have a cordless drill, get one of these sockets for your drill.... It's way easier then using the bar they give you to raise and lower the Stabilizer jacks manually.
Name:	RV leveling socket.JPG
Gerry Z
Curt Trutrack WDH
Old 05-24-2019, 01:59 PM   #11
Bob414
Another vote for Bal Levers. Simply park, put the Bal Lever under low side wheel and use the supplied 3/4 inch wrench to raise to level. No need to chock that wheel either.
Name:	Bal lever.jpg
2014 Flagstaff 206LTD
2008 Nissan Armada LE 4X4 TV
Amateur Astronomer Golf
Retired Electrical Engineer
Bob414 is offline   Reply With Quote
Old 05-24-2019, 02:17 PM   #12
GalsofEscape's Avatar
be sure it is level before you raise the roof. The stress on the lift system can break the cable and i speak from experience.
I used the Bal leveler with my popup - worked great.
level side to side, chock the wheels, then unhitch from tow vehicle and then level front to back using the tongue jack. our Rockwood owners manual had to lower the stabilizers to just snug (they are not jacks) then raise the roof.
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 05-24-2019, 02:18 PM   #13
Grammar Pedant
67L48's Avatar
And another vote. First thing I bought when I got my PUP a few years back. It remains the best RV accessory I've ever bought. It's not close, either.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 05-24-2019, 02:29 PM   #14
this is DEFINITELY the best way to level a Pop Up. Iíve tried just about everything out there when I had my Popup and this sis def what worked best for me FWIW
CyclePilot is offline   Reply With Quote
Old 05-24-2019, 02:48 PM   #15
bikendan's Avatar
Most popular leveling product for owners of single axle trailers. Ask popup owners.
Old 05-24-2019, 04:50 PM   #16
CaptnJohn's Avatar
I have owned the electric 4 points my on a Cougar, the electric 6 point on a HC, and now the hydraulic 6 point on a Montana. I used the wood for leveling for firewood. I have 1 block of yellow plastic blocks that have not been used yet. I put Snap Pads on the HC and Montana. I unhook and push the button. Never a problem.
Old 05-24-2019, 05:40 PM   #17
Just traded in our pop-up. We used one of these
https://smile.amazon.com/BAL-28050-L...L+level&sr=8-2
Level side to side first, then front to back and then stabilizers
MattCrecelius is offline   Reply With Quote
Old 05-24-2019, 06:00 PM   #18
I level with lynx levelers. I have 4 bags of 10 that I used starting with my 2005 Rockwood Freedom 2290 Pop Up, and collected more as needed, for the travel trailers.
DO NOT LEVEL WITH STABILIZERS. Just in case you didn't know, you will twist your frame and do really bad damage to stuff. They are only for stabilizing by keeping the camper movements down (but not completely gone) and keeping the camper from flipping up.
I guess there's a BAL single wheel leveler that looks cute but previously they had failures in the plate welds and bolt threads. Besides on soft muddy dirt, that u shaped bar foot would likely just sink in the mud where wood or lynx levelers would not. Thought about buying the BAL single wheel leveler for it's simplicity and quickness, but always come to my senses when realizing not every site has hard, compacted soil.
I use a bubble level on main sections of the frame that are true, so that I can get a precise indication. Then stack the lynx levelers as high as needed on the low side. Then use the front jack to level front to back.
Good luck and happy camping.
2019 Ford F150 Race Red XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 Locking Axle, 1830# Payload, 12,700# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
Mike91 is offline   Reply With Quote
Old 05-24-2019, 06:03 PM   #19
bikendan's Avatar
This thread is in the Tent Camper and Popup section and the OP said they owned a popup.
Popups don't have such systems.
Old 05-24-2019, 07:23 PM   #20
Four sets of levelers? That is a lot of valuable storage space. I use the Andersons to save space and time. You don't have to guess about the number of blocks and then add or subtract after checking level as its a continuous height change. Although I would think after awhile you'll get fairly good at guessing how many blocks based on the bubble.
https://www.amazon.com/Leveler-Ander...24707035&psc=1
Jeff
2016 APEX 215rbk
2016 F-150 4WD 3.55 3.5l ecoboost
jwfrede is online now   Reply With Quote
leveling
