Old 03-24-2019, 09:51 AM   #1
Lift manual issues
I have a 2008 Rockwood Freedom 1910 and I snapped off the bolt that is used to manually let the top down that is located on top of the worm on the electric motor. Will I need to buy a new motor or is there a way to remove the broken screw? I tried to remove it myself and snapped off the easy out in it too. Where can I find a replacement motor if I need to buy a new one? Thanks
Rlm007 is offline   Reply With Quote
Old 03-24-2019, 07:21 PM   #2
You may want to consider going to a manual crank. I got rid of my electric motor two years ago on my Flagstaff unit and found that cranking does not require much effort and it always works! Robert sales in Denver is where I got my replacement hand crank. The installation was very straightforward.
joefram is offline   Reply With Quote
lift, manual
