Old 03-20-2021, 10:34 AM   #1
Lift Mechanism Maintenance
I have a 2017 Rockwood Freedom 2318G. Can anyone suggest what maintenance I should me doing on the lift mechanism and the winch?
masoptions is offline   Reply With Quote
Old 05-07-2021, 07:04 PM   #2
I am focused on lift system maintenance this weekend on my 2005 Rockwood Freedom 1950. I have identified (1) of the (2) grease nipples on the "Master tube" that runs down the center underside of my unit. I will hit that with a grease gun.
I do not have any troublesome symptoms - so I don't think I will go much further.
Neil Henry
West Concord, MA
neil.henry is offline   Reply With Quote
Old 05-09-2021, 07:46 PM   #3
I have a used 2013 Freedom, and I can tell the previous owner greased the "rear bottom" zerk, but not the "front top" (it was dry). You maybe found the "rear bottom" zerk. Look for another zerk that rather than hangs down is on top of the master tube and a bit more forward / front of the axel(s).
2013 Forest River Rockwood Freedom 282TXR
dduffey is offline   Reply With Quote
Old 05-10-2021, 12:50 PM   #4
Thanks for that pointer.
I have not yet located the rear bottom zerk. (working on a wet driveway this week)
Did you see any need to clean out old grease from the "master channel"?
Thanks.
Neil Henry
West Concord, MA
Old 05-11-2021, 05:48 PM   #5
campfire joe's Avatar
I have a 2318g too. In addition to the 2 grease fittings underneath in master tube i also oil my 4 lift springs and as i raise the roof i put dry lube on the 4 lift posts.
2013 Rockwood popup 2318 g. TV 2016 acadia and a 2013 SLE Sierra p/u
campfire joe is offline   Reply With Quote
Old 05-17-2021, 10:43 AM   #6
Im posting this pic of my 2016 FR 228D goshen system maintenance section of the owners manual and the goshen lift system diagram:
https://ibb.co/Bq1gRFf
https://ibb.co/X3SpTvM
flyerdp is offline   Reply With Quote
lift, maintenance
