Lift system issue
Sorry for the length but I need to explain. We bought a 2001 Rockwood Freedom Tent Trailer. The man we bought it from had bought it as a project. He replaced rotted wood in the roof on the door side and purchased a new spring set for the front of the Goshen lift system. He was able to use the camper once before the lift system stopped working. He pulled the front spring system out to discover the door side spring was bent. He got frustrated and sold the camper. We bought it cheap because we foolishly thought we could fix it. We bought a replacement spring, installed it and tried to put the top up. It went up just over halfway before it felt like the crank was bound up. Hubby pushed the crank beyond the place that it felt stuck, it suddenly let go, the crank turned freely and the rear of the top went up but the front didn't move. We cranked it down and had to push the front down by hand. We pulled the spring and the door-side spring was bent in two places about 2" apart. We then pulled the cable out to check it and discovered the push plate was bent/folded back onto the cable, like a U. So we got a piece of 1/4" steel and made a new one. We ordered another new set of springs, made sure everything was well grease/lubricated again and tried to lift the top. This time it only went up about a foot. As soon as we felt resistance in the crank we stopped and cranked it back down. Again, we pulled the spring out and it was bent really badly, it is in the shape of a Z. The bend or crimp or jam or whatever it is is happening on the door side within the main channel under the camper. PLEASE Has any ever seen this happen? Do you have any suggestions on how to fix it, or where else to look. I have called Forest River and they are as confused as I am.
