Old 07-11-2020, 11:54 AM   #1
Lift system not working on battery
Hey guys,
The pop-up we recently got (2017 1910ESP) has a 12V power lift system but it seems to only work when plugged in to shore power and not off the battery.
I've confirmed that there is a connection from the battery to the winch.
Noticed at the battery connection theres this ShortStop device between the battery and winch as well. (Picture attached)
Just wondering if any thoughts on this. Is the battery short or is it this ShortStop device that's causing it to not work on battery?
I'm leaning towards battery is shot.
Thanks guys
-Eric
eric_hoog is offline   Reply With Quote
Old 07-11-2020, 12:03 PM   #2
Chris Pastuzyn's Avatar
That looks off, like it got hot, Do you have a meter ? So you can get a voltage reading on the battery and see if there is voltage out of that short stop.
Chris Pastuzyn is offline   Reply With Quote
Old 07-11-2020, 12:09 PM   #3
Thanks for the quick reply, I do have a voltmeter but last time I check the battery it seemed within an accepted range but had shore power hooked up for a while and was disconnected before checking. So was likely charged and not a good read on if its holding charge.
Never thought to check voltage coming from ShortStop that's a great idea.
Battery hasn't been plugged in for weeks now so will check reading on battery and out of ShortStop and post back.
Thanks again!
-Eric
Old 07-11-2020, 01:41 PM   #4
Sooo looks like it's the battery is shot it was reading 2.5V so yeah guess that's my first problem lol. Gotta love that the dealership sends you off with a crap battery.
Thanks again for the help. Once I get a new battery and test I'll let you know.
-Eric
Old 07-11-2020, 02:40 PM   #5
Just as confused as you
Scrapper's Avatar
Depending on how well the previous owner took care of the battery they can go bad pretty quickly. You don't know if they boondocked and let the battery get below 50% capacity which is around 12.1 volts.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 07-11-2020, 02:45 PM   #6
Flybob's Avatar
Thanks again!
-Eric
If you do not have a battery disconnect switch or disconnect one side of the battery and leave the PUP not connected to shore power for a few weeks, it will drain the battery. The CO/Propane detector and possible the radio are all drawing enough parasitic current to drain the battery especially if it is older.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-11-2020, 02:58 PM   #7
Thanks guys both of those are great pieces of info for a newbie here.
I'm assuming the battery was already in bad shape since when we were picking up the trailer and got the "demo" the guy mentioned the lift didnt work off the battery.
Will definitely look into disconnecting the battery when not in use as well to save the new battery I get as well.
Old 07-11-2020, 03:25 PM   #8
Flybob's Avatar
You can also add a disconnect switch. Something such as this. https://www.amazon.com/Ampper-Batter...omotive&sr=1-3
TST Tire Monitors
2 100W solar panels
Old 07-11-2020, 05:29 PM   #9
If you can find a true deep cycle get one. You might need to go to a battery dealer. Something like a DC12. Or if you're feeling spunky you can go with series 6v golf cart (Costco has them).
On the pup I had when I first saw that tiny bus bar and Short Stop installed I couldn't type what I said to myself here. My Jayco TT actually has them mounted with the brackets.
brwarrior is offline   Reply With Quote
Old 07-11-2020, 08:30 PM   #10
Scrapper's Avatar
You might want to read "The 12 Volt Side of Life" in the forums Library section. Here is a post from wmtire with several links that are useful for people new to rv's.
https://www.forestriverforums.com/fo...ts-157524.html
Richard & Jill
Camping since 1989
Old 07-12-2020, 12:52 PM   #11
Thanks guys will look into that. Just read through the 12 V side of life article which had some really good information in it as well.
Will look into getting a good deep cycle battery that fits my mount for now and probably just manually disconnect the battery for now when not in use but the disconnect switch is something I'd think I would want to add eventually too and maybe even a voltage monitor but again will stick with the multimeter for now and get a grasp on the basics of it all.
Thanks all! This forum is awesome!
Old 07-12-2020, 01:29 PM   #12
camaraderie's Avatar
mini tip...get a wing nut for your new battery negative terminal to make it easy to remove the negative wire when not in use. ONLY measure battery voltage AFTER 24 hours of disconnection from use or a charger. Voltage readings for state of charge are based on a STATIC battery which cannot be achieved in use.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 07-12-2020, 02:30 PM   #13
Battery
Need to check specific gravity not voltage
Eddthefed1 is offline   Reply With Quote
battery, lift
