Old 10-03-2020, 11:58 AM   #1
Lightning pilot light
I just bought a 1640ltb, I can't get the pilot light to light.
Gas is on, put the knob on high pressed the ignition button and nothing, tried clicking the thing 100 times.
Is there something I'm doing wrong??
TheFriendlyUser is offline   Reply With Quote
Old 10-03-2020, 12:03 PM   #2
bob213's Avatar
On mine the ignitor does not work for the oven. I use a long lighter. If yours is designed to start the oven try purging the lines by lighting a top burner first. Then you will know air is out of line and oven may light. Good luck.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 10-03-2020, 12:21 PM   #3
It's just for the furnace, I think .
Old 10-03-2020, 02:40 PM   #4
Furnace and hot water heater are DSI. The refrigerator is not. This must be refrigerator which is hard to light because unless it's really dark outside, you won't see the pilot flame.
I always make sure the gas lines have gas in them by lighting a stove burner first. After that I know the gas line is pressurized.
I light it and then turn it off, and listen for the flame to go out. If I can confirm it has been lighting, I do it again and assume it has lit. Wait 5 minutes and check for heat out of the stack. If it is hot, your pilot light is lit.
In the dark it's very easy because you can see the pilot flame.
2019 Ford F150 Race Red XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 Locking Axle, 1830# Payload, 12,700# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
Mike91 is offline   Reply With Quote
Old 10-03-2020, 04:47 PM   #5
What refrigerator do you have? Every RV fridge Ive owned has been DSI.
phipps33 is online now   Reply With Quote
Old 10-03-2020, 05:19 PM   #6
Originally Posted by phipps33 View Post
What refrigerator do you have? Every RV fridge I’ve owned has been DSI.
Not in a standard height pop up. Yes, in a travel trailer and maybe a high wall pop up but not in a regular pop up that uses a 1.9 CF or 2.5 CF ammonia absorption refrigerator.
Old 10-03-2020, 05:32 PM   #7
Weird, every standard wall, regular pop up I've had since 2005 has had a DSI furnace that uses no pilot flame.
Since you have a 1640 LTD, I don't think it's your furnace. If you have a refrigerator and not a icebox, then it's your refrigerator.
Old 10-03-2020, 06:39 PM   #8
Now that you mention it, one of our early pop ups had a fridge with a pilot. I completely forgot about that one.
Old 10-03-2020, 06:58 PM   #9
Yes it's a frdge it is a Domestic.
Old 10-03-2020, 07:03 PM   #10
Mr. Dan's Avatar
OK. That clears up the furnace/fridge question. Now... if you do any searches, spell Dometic like the company does - without the 's'.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 10-03-2020, 07:09 PM   #11
Yes it was an auto correct, but yes there is no S haha
light, pilot light
