Old 08-07-2023, 07:35 PM   #1
Cowboy6201's Avatar
Looking at trading in our HW296 for a travel trsiler
Where gonna trade in or 2018 Rockwood HW296 for a Rockwood Mini Lite, not sure which model we're goona get yet, we're gonna look at the 2507s or 2516s.
2020 Ford F-150 Limited
Color Rapid Red
2018 Rockwood Premier HW296
Cowboy6201
Cowboy6201 is offline   Reply With Quote
Old 08-07-2023, 08:38 PM   #2
Campworthy's Avatar
But you've just done all those mods?? New sink, step, tv!! How come you are trading, have you run out of mods to do, so now you are bored?
2018 Flagstaff HW27ks
2019 Toyota Tundra
Campworthy is offline   Reply With Quote
Old 08-07-2023, 09:00 PM   #3
bikendan's Avatar
Since you have a bling F150 Limited, that trim level tends to have "Limited" payload capacity.
You're probably fine with the loaded tongue weight of the 2507S. But the 2516S may push up against your payload capacity.
When I was looking at F150s, Limited models often had payload capacities at 1000lbs or less.
Let us know what the driver's door yellow Tires and Loading sticker says. It'll say "Occupants and cargo should not exceed xxxxlbs". Driver is considered as one of the Occupants so their weight must be subtracted from the payload amount, just like the passengers, truck cargo/add-ons and WDH weight.
Old 08-08-2023, 11:03 AM   #4
Cowboy6201's Avatar
The TV Comes out the original Furrion TV goes back in it. The New TV will replace the cheap Furrion in the new trailer.
Color Rapid Red
Cowboy6201
Old 08-08-2023, 11:42 AM   #5
FYI looks like Rockwood eliminated the 2507s for MY 2024.
2023 F250 Lariat Supercab SB 4x4 7.3l 3.73
Currently without travel trailer
Sbadocko is offline   Reply With Quote
Old 08-08-2023, 12:05 PM   #6
Cowboy6201's Avatar
The Sink had to be replaced, it had cracks around the drains.
The old step was rusty.
I now need to replace the stabizer Jack's, the pads disingeaded and the Jack's are very rusty so even if I replace pads I'll still need to replace the Jack's.
I live on Cape Cod were I'm surrounded buy salt water and things rust up fast and don't last if it's not Stainless or non rust proof.
Color Rapid Red
Cowboy6201
Old 08-11-2023, 01:24 PM   #7
Cowboy6201's Avatar
Here's the sticker on the door frame. Click image for larger version
Color Rapid Red
Cowboy6201
Old 08-11-2023, 01:29 PM   #8
bikendan's Avatar
Here's the sticker on the door frame. Attachment 291281
Just like I thought. My non-bling XLT F150 3.5 Ecoboost SuperCrew has a payload capacity of 1828lbs.
So for the 2516S, using 12% of the trailer's GVWR, for a ballpark loaded tongue weight, gives you a ballpark loaded tongue weight over 900lbs.
Now add 350lbs for driver and one passenger and 100lbs for the WDH, adds up to 1350lbs against your 1190lbs of payload.
That's 160lbs over truck's payload capacity, and that's with no more passengers and truck cargo.
That's why I said that the 2516S is too tongue heavy.
The 2507S gives you a little more room but you have to add up how much is going to be in the truck. And the 2507S has been discontinued for 2024.
Old 08-11-2023, 04:27 PM   #9
Cowboy6201's Avatar
I going to look at a 2509s leftover 2023 and a used 2022.
Color Rapid Red
Cowboy6201
Old 08-11-2023, 04:44 PM   #10
bikendan's Avatar
Do you realize that the 2509S has the same basic fictional dry tongue weight, as the 2516S?
So you'll run out of payload capacity on that trailer too.
You have to realize that your F150 has a poor payload capacity and that dry tongue weight numbers are fictional, because they are based on a stripped-down version of the trailer.
hw296, travel
