Old 07-31-2017, 07:55 PM   #1
Amartin453's Avatar
Lug wrench Located
I do not recall having or seeing a lug wrench that came with my 2016 Rookwood Premier 2516g. I would assume one comes with the trailer?
Anyone know the top secret spot It may be or have a picture of what it looks like, I assume it looks like a typical lug wrench....
Amartin453 is offline   Reply With Quote
Old 07-31-2017, 07:58 PM   #2
Flybob's Avatar
Trailers do not normally come with a lug wrench ( or a jack). Be aware that most TT lug nuts are different from what is on the TV. Determine the correct size then purchase one at you local auto parts store.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-31-2017, 08:17 PM   #3
what would one use to change a flat, in place of a jack, or is there a particular type of jack made for this?
we do have a 4 way lug wrench
no jack
ValMelton is offline   Reply With Quote
Old 07-31-2017, 08:52 PM   #4
exploreco's Avatar
Nope, no jack or lug wrench came with the pop up. I keep a breaker bar with a set up sockets and a bottle jack in a tub in the back of the truck.
2020 Rockwood Roo 235S
2010 Ford F150 Lariat
Nights Camped in 2021-?
2020-8, 2019-27, 2018-12, 2017-29, 2016-33, 2015-22, 2014-22, 2013-20
exploreco is offline   Reply With Quote
Old 07-31-2017, 09:01 PM   #5
SailorSam20500's Avatar
Bottle jack AND something to put it on - make sure the jack will actually get the wheel off the ground!
Al
Save the Earth. It’s the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 07-31-2017, 09:05 PM   #6
Oaklevel's Avatar
That's correct no lug wrench or jack comes with nearly any trailer. I say nearly as there could be a rare company out there, but I doubt it. A spare tire does not either they usually are an option.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-31-2017, 09:15 PM   #7
exploreco's Avatar
Yeah, your right about that. I probably should try it out sometime in the driveway to make sure it does what I need it to do. Fortunately, have never needed it, but would be nice to know it works when you need it to.
Old 07-31-2017, 09:45 PM   #8
clr
A standard lug wrench will not fit or work properly on many rv wheels that is especially true with aluminium wheels since they use acorn type nuts that are longer than the standard lug nut. I would suggest finding the proper size in your driveway or someplace but trying sockets until you determine the proper size. Also many are now metric sizes so you will have to try them also. Then if you have aluminium wheels go to the auto parts dealer and buy that size socket for removal of mag wheel nuts. Then all you have to do is carry the socket and wrench an extension and a bottle jack and a couple of stout boards. Easy peaze.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-01-2017, 08:26 PM   #9
Remember, the side of a road may not be as friendly as your driveway - I setup to have an extra few inches of lift, just in case!
Al
Old 08-01-2017, 10:44 PM   #10
If you have the lugnuts with the fancy chrome cap, go get 10 solid ones and toss the originals. Corrosion gets under them maki g them swell and a real pita to get off. Just had a blowout and all the preparedness in the world didn't prepare me for that.
The scissor jack for my truck works great. You need a thin wall 4 way for the aluminum rims on my 2516g.
Good luck
2014 Rockwood 2516g
2011 Ram 1500 quad cab 4.7 4x4
Bhugo is offline   Reply With Quote
Old 08-01-2017, 10:50 PM   #11
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
And invest in a torque wrench.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
cat
