FWIW, I found with pop-ups and A-frames that it was easy to induce just the slightest bend in the frame when I put stabilizers down before I was finished with the camper setup. Just a slight twist in the frame meant the door no longer fit properly on a pop-up and the side panels on an A-frame wouldn't latch properly.
So I moved putting stabilizers down to the end of the mechanical setup. Even though I try to avoid having the stabs down beyond just kissing the ground, sometimes DW wants a little bit more stability when moving around in the camper so I put another quarter to half turn on. Happy wife, happy life.
Yes, if you climb onto the extended rear bunk before the stabs are down, the tongue will lift and the rear bumper go to the ground. Got the t-shirt for that ride. But I've never had the rotation happen if I stayed inside the box until the stabs were down.
Fred W
2019 Flagstaff T21TBHW A-frame
prev 2 pop-ups, 1 A-frame
