Old 05-26-2020, 09:15 AM   #1
Malfunctioning switch raise & lower pop up
Greetings,
I'm seeking words of wisdom.
I have a 2015 Rockwood 2716G Pop-Up. The switch to raise and lower the top isn't working. I've replaced the motor with now imporovement. The brand new motor gives the same symptom. A buzz but it won't raise or lower the top. I have to gently use my drill to get it up and down. Is there a switch I should buy to resolve? What else should I be checking to resolve this issue?
Thanks.
Camper Tim
Timcamper is offline   Reply With Quote
Old 05-26-2020, 11:53 AM   #2
Head Rambler
If the motor is humming but the actuator isn't moving I doubt that the switch is the problem. Most likely the gearbox. Your drill most likely develops more torque than that lift motor does so it will lift it.
Gotta go campin!
Old 05-31-2020, 09:02 PM   #3
Amartin453's Avatar
You can try changing out the switch first, simple and very in expensive. If that doesnít work, you can try changing out the relays, another in expensive part. Or bring it to a repair shop for them to diagnose.
My switch and relay both went at different times and I replaced them. No issues anymore!!
Amartin453 is offline   Reply With Quote
pop up, switch
