Originally Posted by Reverse_snowbird
My concern would be with what happens if you can't push it the slope with the dolly.... or if you get partway up and the pop up moves back toward you.
Walmart has a motorized one for under $300.
https://www.walmart.com/ip/VEVOR-Tra...571762&veh=sem
It would be a lot cheaper and safer to take the time to learn to back it into the garage. It's a challenge. We had a 20' trailer that we backed into a storage garage and it took forever to learn how to do it with the narrow driveway, but after much 'blue air' at first, we did learn how to do it.
and
Welcome to the forum!
Buy it direct from VEVOR, its fast shipping and at least $50 cheaper:
https://www.vevor.com/trailer-dolly-...p_010614875313
I have one and take my 3300 lb camper in and out of the garage. It only works on I believe its a 3 or 4% grade. Mine is 2.5. To get it up the lip in to the garage I get the tire against the lip then I use a 2 x 6 that is 4 or 5 feet long that I split along the skinny edge at an angle matching the slope of the driveway. With the back half of the board in place behind the wheel I move it away from the garage with the mover until its elevated at the board height off the ground. Next put the other half of the board in front of the tire now and you will have a whole board that elevates your camper to the height of the garage lip (assuming its only 1.5 inches or so tall) and you can drive it right in at the grade of the lip. I had a video somewhere if I can find it I will post.
To be clear the board is cut at an angle but not completely. There is about a 1 foot flat spot for the trailer to rest on while positioning the other half of the board.
I also custom made a bracket to mount it on the tongue frame so I didnt have to make holes or mount anything permanently.
Most new FR trailers have electronic brakers. Make sure they are powered when moving the trailer by hand or with the above mover and keep a hand on the emergency pull cable. If it gets away from you for some reason you can just pull the cable and the trailer will stop instantly.
