08-27-2018, 09:41 PM
My grey water to 3in sewer mod
Ok it’s not really a “mod” as much as it’s my solution to a problem that never should have been a problem. We full hookup camp about 90% of the time. Family with young kids it’s just the only way to go. So why would forestriver not connect the grey water tank to the black 3in dump like EVERY trailer on earth?!?!? I know people have replumbed the grey to the black. Maybe I will too until then here is my solution. I used a sewer clean out adapter (had to remove the one way rubber flap with pliers). I still have a ball valve to keep black water from going in to the grey water tank. Then I simply attached a short hose and done! I can take a shower and use the sink as much as I want. I only drain the black when it’s full. Cheap and easy solution.
08-27-2018, 09:54 PM
Is that a standard sewer connection on the gray tank dump?
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
08-27-2018, 10:27 PM
No. It’s a 1.5in grey water valve.
I suppose it’s a standard 1.5. But not a 3in.
08-28-2018, 08:06 AM
Recently new!
Nice way to git’er done!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
08-28-2018, 08:19 AM
so, you have to have a 2nd 1.5" hose to deal with?
08-28-2018, 09:35 AM
Yeah. And they done make a 1.5 in hose that I’ve ever seen. They only make a screw on adapter to hook up a garden hose. It’s so dumb.
08-28-2018, 01:34 PM
But I can see what looks like a standard sewer hose connection in your photo of the grey dump valve. Is that the original valve gate?
Other than that I think you are right to be irritated.
2017 Dynamax REV 24RB
2018 Ford F-150
08-28-2018, 02:53 PM
Genius!
I re plumbed mine with tees, black pipe and a 1 1/2 valve.
Your arrangement in the way to go.
08-28-2018, 05:19 PM
It’s a threaded inch and a half valve. I screw on a hose adapter like this.
08-28-2018, 09:26 PM
Interesting, never saw that before.
2018 Ford F-150
08-28-2018, 11:06 PM
Me either. However I was looking at my parents toy hauler and the grey tank valve is a 1.5in to 3in. Apparently most grey water dumps are 1.5. But since it connects to a 3in common drain it’s no big deal.
08-29-2018, 11:44 PM
Ok it’s not really a “mod” as much as it’s my solution to a problem that never should have been a problem. We full hookup camp about 90% of the time. Family with young kids it’s just the only way to go. So why would forestriver not connect the grey water tank to the black 3in dump like EVERY trailer on earth?!?!? I know people have replumbed the grey to the black. Maybe I will too until then here is my solution. I used a sewer clean out adapter (had to remove the one way rubber flap with pliers). I still have a ball valve to keep black water from going in to the grey water tank. Then I simply attached a short hoes and done! I can take a shower and use the sink as much as I want. I only drain the black when it’s full. Cheap and easy solution.
Nice job! You obviously had vents for your shower and your sink. Otherwise you would get an air lock, not allowing you drain through your hoses.
On my previous 2007 Starcraft, I had a vent on the shower but didn't have a vent on my sink. So I had to make my own vent so that the water would flow through the hose to my blue tote.
The new 2019 2318G I'm looking at doesn't have a vent on either the shower drain or the sink drain. So I may make it easier on myself and put my blue tote directly under the shower drain and drop hose directly into blue tote, leaving blue tote vented. And for the sink drain, dropping a hose right to a bucket. I can either pour bucket into a toilet or into the blue tote. That way there less hose length and vent fittings to have to mess with.
2019 Ford F150 Race Red XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 Locking Axle, 1830# Payload, 12,700# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom , Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
08-30-2018, 09:55 AM
I didn’t see any additional vents on my sink or shower tank. I haven’t had any air lock issues. You shouldn’t have any air lock issues. The way I drain it to the 3in its the same as if you just hook up a hose to drain it to your blue tote. Just think of the 3in black as your blue tote. It’s definitely vented. You do have a vent. It’s the drain in your sink and shower worst case (if you have a shower). It’s definitely possible I’m missing something but, If it will drain in to a tote it will drain to a hose. It has to be vented or you wouldn’t be able to fill it. It would slowly fill with air burping back every time water replaced air.
08-30-2018, 10:36 AM
I guess I am confused as to what I am looking at as we have one dumping point for all three tanks.
But just a question could you use two "Rhino" hoses with a "Y" connector and have the same thing??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-30-2018, 11:43 AM
That looks much easier than what I was using
Just glad to get away
08-30-2018, 09:34 PM
I suppose I could. I couldn’t find the correct adapter.
09-03-2018, 08:52 PM
Ya my problem exactly.
here is my setup.
My Mom had a Fleetwood Niagra Pup, which was done right with the Gray water draining into the black water with 2 shutoff's, so when u drain the black water u close the valve to the gray water or vise versa.
Ur right forest river needs to get it right. I was hoping when I traded in my 2010 296 with the same issue they fixed it in 2018.
Once my 5yr extended warranty runs out I'm gonna fix the problem and make it right.
2018 Rockwood HW296.
2017 Ford Explorer Sport3.5L Twin Turbo
2018 Rockwood Premier HW296
Cowboy6201
09-04-2018, 07:27 PM
My former popup has Black Tank and 1-1/2 or 2" outlet T valve. I used a Y connection setup like you did, left a loop at the bottom to give a seal from gas coming back up. Left grey valve open.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
09-04-2018, 07:28 PM
I also made up a short hose just for this hookup.
24WS
FX4 Off Road (4X4)
