Old 09-25-2020, 11:44 PM   #1
New battery no power....? FRUSTERATED
PLEASE HELP!!!!!!
just bought a used 2006 Flagstaff 205 tent trailer.
When I brought the unit home last week the battery would only control the power winch. In order to control lights, pumps etc. i had to be plugged into 120 v house power.
As I was trouble shooting that issue I noticed the battery was getting very weak each time I used the power winch i lowered the unit unhooked the battery and charged it up. I re-hooked it tonight and had absolutely no power yet it was reading 13.47v on the testing meter.
So I just went to costco and picked up a new deep cycle battery expecting the winch and hopefully all electrical services to work...and nothing will work.
What is happening here?? Please help.
Thanks Geoff
Vic BC
welly is offline   Reply With Quote
Old 09-26-2020, 05:54 AM   #2
Are you sure you hooked the battery up correctly? If backwards, it could have blown fuses. Check on your converter. You also could have a tripped breaker. Follow the positive cable and you should find a small metal box attached with a reset button. Good luck!
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 09-26-2020, 09:24 AM   #3
Your reading must have been while plugged in to 120ac and the convertor functioning. That is not the true battery voltage. Guessing hooked up cables backwards.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 09-26-2020, 09:27 AM   #4
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. If your winch would work (originally) and the lights only on shore power check the cable from the battery to the converter. Also what Joe said
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-26-2020, 12:35 PM   #5
It's extremely important to have a good ground connection from the battery to the frame.. Alot of crazy things occur when there isn't a good connection...i would start there.
Jimswim is offline   Reply With Quote
Old 09-26-2020, 05:59 PM   #6
BillyBass's Avatar
Did you clean the cables they might be corroded
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 09-26-2020, 07:33 PM   #7
I'm not particularly sharp on electrical stuff but in addition to the comments already given, might there be a short somewhere that's dragging you down?
Also, new batteries are not necessarily well charged when you get them- and you could expect the old battery to be discharged anyway.
Let me put in my plug for long battery-LOW AMP charging only. I sold a Jayco that had an Interstate deep cycle 12V battery that was at least 13 years old. Remove in winter and charge low AMP off and on all winter when you think of it.
Foothills is offline   Reply With Quote
Old 09-26-2020, 07:53 PM   #8
Falconer's Avatar
For some reason, battery volts and amps are not getting to your electrical loads such as lights, winch, etc.
Learn how to use a voltmeter and get comfortable with it. You can pick up a decent inexpensive one for prob $30 or less. Read your voltage at the battery, should be about 12.7 if the battery is fully charged. Then move the meter leads one connection at a time until you find the place where the voltage drops significantly.
Most common issue, and where I'd put my money if I were a gambling man, would be a bad ground connection somewhere.
Learning where the circuits go will really help you when odd things go wrong.
Look for loose or corroded connections. Look for blown fuses (not likely in this situation). Since it's affecting multiple loads, it's probably something upstream from the power distribution center. Shouldn't be too hard to find...
Charlie
Falconer is offline   Reply With Quote
Old 09-26-2020, 07:55 PM   #9
Boscorelli's Avatar
Originally Posted by welly View Post
1. I re-hooked it tonight and had absolutely no power yet it was reading 13.47v on the testing meter.
2. So I just went to costco and picked up a new deep cycle battery
I'm sorry, but I don't follow your logic? Your old battery tested good, so you bought a new battery?
My logic says the fault is NOT the battery, but some other component of the electrical system.
Boscorelli is online now   Reply With Quote
Old 09-26-2020, 08:09 PM   #10
BillyBass's Avatar
do you have a disconnect and its turn off which kills the battery to camper
Old 09-26-2020, 09:26 PM   #11
Bob414
My 2 Cents:
I do not have a power lift, but as I understand them they are directly connected to the battery via a fuse or circuit breaker.
All other DC loads normally use the converter for power distribution.
If you tried to install battery and reversed the leads on the battery only momentary, that normally blows the reverse power current fuse in/on the converter, usually the largest (Amp wise), and normally located away from the other DC fuses.
Check all DC fuses in the converter.
There is also a safety cutoff, that prevents the ceiling lights and fans from being left on when closing the top. If you have a fold down sink, it is normally located on the surface the sink fold down on.
I installed a battery disconnect on my battery to stop parasitic loads from draining the battery. Parasitic loads include low battery and CO2/Propane alarms as well as a possible memory on a radio. However my battery disconnect totally disconnects the battery so your lift would not work.
The weakest point in the DC electrical system, in my opinion is the ground wire nut used to connect all DC grounds together. My electrical background, limits 4 wires to a wire nut. The one in my camper had 9 wires connected and I replaced it with a ground bus strip.
If other DC loads work, water pump, DC refrigurator etc. Then there is the connecting wires to the ceiling, normally near in one the corners. check to see if they got pinched somewhere.
Good Luck!
Bob
2014 Flagstaff 206LTD
2008 Nissan Armada LE 4X4 TV
Amateur Astronomer Golf
Retired Electrical Engineer
Bob414 is online now   Reply With Quote
Old 09-26-2020, 09:36 PM   #12
BillyBass's Avatar
Is there a fuse link on the red wire to the battery it might be blown
Old 09-26-2020, 09:37 PM   #13
Tom48's Avatar
PLEASE HELP!!!!!!
Thanks Geoff
Vic BC
Everybody on here gets excited to help you diagnose and correct your problem..
Please be sure to come back online and share the solution when you resolve it.
In part, it's our reward for studying your problem and offering suggestions. BTW, I'm offering nothing because, concur with what most everyone has offered.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
Old 09-27-2020, 08:14 AM   #14
bedubya's Avatar
PLEASE HELP!!!!!!
Thanks Geoff
Vic BC
A fully charged 12v battery will read about 12.7 volts. You were reading the charging voltage from your converter. Unplug shore power then check your battery voltage.
Make sure the wire from the (-) post of the battery goes to the trailer frame and connections are tight.
Follow the wire from the (+) post of the battery to the converter. There is probably an inline fuse somewhere. Check it then check the fuses in the converter.
'17 Toyota Tacoma 4x4 TRD Sport
'17 Salem Cruise Lite 232RBXL
'08 Kawasaki Vulcan Classic 1500
Mickey the Rescue Project Schnauzer
Days Camped: 2017-39, 2018-61, 2019-64
bedubya is offline   Reply With Quote
Old 09-27-2020, 08:34 AM   #15
Flybob's Avatar
Tent trailers ( pop-ups) have a safety switch that are activated when the unit is set up. This is to prevent the lights from being on when the unit is collapsed. This is usually plunger switch. If it is stuck or damaged, it will prevent power from flowing to anything on the roof. There is a reverse polarity fuse in line with the battery. If the battery is connected backward it will blow the fuse.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
battery, power
