Originally Posted by morrama
Well hopefully I didn't burn it up
Amanda, are you talking about the switch inside your popup to the water heater, since many of your type trailers don't actually have an electric heating element too?
If you are talking about the inside switch (which is to the gas/propane), you should be fine.
You most likely do not have an electric heating element to burn up.
EDIT: I looked up your RV specs at the Forest River website, and it appears you only have a propane water heater (no electric element). You should be OK, but do need to turn it off while towing. If they closed your propane cylinders, it couldn't light up anyway.
Here is what the webpage states and shows as standard on your model:
http://www.forestriverinc.com/campin...usiast-package
Hot Water Package (incl Water Filter, Outside Shower, Six Gallon DSI Hot Water Heater, Demand Water Pump) (Opt 206STSE, 207SE; Std 228BHSE, 23SCSE, 28TSCSE)
