Originally Posted by PTMinSTL
Once I was able to open it up I found that the 30amp battery fuse on the converter was blown. If it happens again, what could cause that fuse to blow?
To answer your question....Obviously, reverse polarity like the battery being hooked up incorrectly.
Also, the campground connection could have 'reverse polarity'. We've encountered that in both public and private campgrounds.
If you don't have one, get a surge protector or EMS that checks for reverse polarity and check the post before you plug the camper in. Obviously, if it detects 'reverse polarity' don't plug in and tell the office and find another spot. Don't let the 'electrician' on site tell you that reverse polarity doesn't matter. It's your camper and you need to make certain it's getting proper power.
An EMS will usually not allow power to the camper if it detects something wired incorrectly.
