Originally Posted by Ford Idaho
Do you have a blow dryer or other corded appliance that you can plug into the 110 outlet on the pedestal?
X2. In these situations, you always verify power at the campground pedestal first, then work your way forward.
Even though the 15/20 amp outlet on the pedestal may work, it's no guarantee that the 30 amp outlet is working....but is a good place to start.
Another thing, is with a popup, you probably have a plunger switch or similar in your kitchen or bathroom, that must be engaged with a wall/cabinet for power to turn on. This is a safety feature that in case you leave a light on, and collapse the top, it cuts power to the RV so the light won't burn up the canvas.
I'm not familiar enough with your particular model to know if this just affects the 12 volt DC, or the also the 120 volt AC.
