Originally Posted by Nrollins
I have a 2021 1640LTD, and noticed something interesting recently while I was NOT connected to shore power. The overhead lights can be switched on while the sink is flipped down (kill switch thus not depressed yet) and the lights actually come on, although in a very dimmed capacity. When I press the kill switch down, they light up fully.
Does anyone know if this is a safety measure (I.e. you can have a tiny bit of light if needed while working on the camper and not fully setup)? Or could there be some cross wiring mistake? I always had the understanding the 12VDC supply was FULLY disengaged until the kill switch gets engaged.
It's not a safety measure. Because LEDs use so little current, a stray strand at a switch or terminal is enough to cause what you are seeing (most likely). Another possibility is the kill switch leaking voltage/current in the open position (not depressed). The other possibility that comes to mind is a poor ground connection.
The sensitivity of the LEDs to a wiring or switch fault is actually a good thing in this case.
Fred W
2019 Flagstaff T21TBHW A-frame
