Old 11-14-2021, 03:25 PM   #1
Pop up camper motor switch
The switch on my motor works intermittently . I have replace switch and still the same. Any tips or tricks on where to go with it next ? 2018 forest river rock wood 1640 ltd. You guys helped me with a stripped gear last week and got that all buttoned so thanks for that as well.
Gkuchta is offline   Reply With Quote
Old 11-15-2021, 08:35 AM   #2
SeaDog's Avatar
I would take a look at the motor and motor connections if it is still doing the same thing with the new switch.
Retired Navy
2016 Flagstaff 26 FKWS
Old 11-15-2021, 09:34 AM   #3
I assume the motor in question is for raising the roof and not the water pump?
There is a double relay pack on the underside of that whole assembly that the switch actually controls.. Remove the lower cover to see it better. It is a little difficult to get out and rivetted in. I replaced the rivet with a bolt and nylon locknut and lock-washer for future removal.
I made a post about diagnosing it:
https://www.forestriverforums.com/fo...ml#post2624179
flyerdp is offline   Reply With Quote
camper, pop up, switch
