Originally Posted by MohicanJeff
Check along the inside edge of the roof along the sides and see if there is a mechanical switch. This removes power from lighting when the top is down to prevent overheating. I have read numerous posts of these going bad. I’m sure you could bypass the switch to test.
X2 as my first guess for the culprit. This is usually a plunger switch that is "normally closed" (on) when the roof is raised, but when you lower the roof, a portion of the roof makes contact with the plunger and "opens" the circuit (turns it off). Some campers have this switch in the flip-open kitchen, and it accomplishes the same thing.
These tend to be troublesome because they aren't that well supported. Yours may be stuck in the open (off) position, or it may have come adrift entirely and the connectors might not be hooked to the swich anymore.
This video shows, IN PRINCIPLE, how this works. On Forest River products, the switch itself is likely to be different. The Coleman version is "normally open" and is closed when you set the kitchen in place.
I had a Rockwood High-Wall, and this switch was on the edge of the tub, and closing the roof pushed the plunger. In a "low wall" (standard) popup, putting them in the sink area...sandwiched between the base and the "flip away" portion makes more sense.
This image is from another thread in the Forest River forum...on the same subject.
https://robertssales.com/images/opti...off_switch.jpg
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at
Lake Vallecito.
