Old 01-19-2018, 01:51 PM   #1
Popup bed slides
My 2017 rockwood 2516G, the rear bed gets stuck a little ways out. Tomorrow I知 planning on trying to lubricate the slides tomorrow but I知 not sure what to use. I have some silicone spray I知 going to use unless I need a different compound. Any tips? Thanks everyone.
Ckwoods14 is offline   Reply With Quote
Old 01-19-2018, 03:20 PM   #2
Always Learning
Silicone spray is like my Frank's Red Hot Sauce - I put that s$#@t on everything.
I recently found one from WD40. It's still a spray silicone but leaves more of a residue behind. It's really fixed the squeal of my scissor jack.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 01-19-2018, 03:28 PM   #3
Flybob's Avatar
I had good luck with a bar of soap.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-22-2018, 02:49 PM   #4
Grammar Pedant
67L48's Avatar
I had a love-hate relationship with silicone spray. I loved the way it would not leave a dust-attracting residue. I hated the way that it didn't lubricate nearly as well as oily, greasy lubricants.
Find a squeaky door hinge in your house. Use silicone spray on it. See how long it stays quiet. I could measure that in days in my house, with light use. Now, put some WD40 or equivalent on that same hinge. My hinges stay quiet for months.
So, know that the silicone is a continuous application. You'll need to lubricate very often.
And, as you know, never struggle with a PUP, because you will almost always win ... and you'll win at the expense of canvas/vinyl, hinges, and other structural components that aren't as strong as you are.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 01-22-2018, 04:00 PM   #5
Keystoner's Avatar
Protexall: Super Slick Stuff is what I used on my Coleman bed slides. I now have a 21SS hybrid and when the slide out started squeaking I sprayed the gears and tracks with it.
I don't know how it works but it seems to do well and lasts.
Keystoner is offline   Reply With Quote
Old 01-22-2018, 04:04 PM   #6
That stuff looks like it does a lot, I値l take a look at it
Old 02-09-2018, 02:59 PM   #7
What I started using on my slide out is a spray motorcycle chain lube. That stuff lasts quite a while. It is a little thicker than silicone and worked for me.
Skiddy is offline   Reply With Quote
Old 02-09-2018, 10:16 PM   #8
Velosprout's Avatar
I used 3-In-1 garage door lubricant spray on my Rockwood pop up slide-out bed tracks.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
Velosprout is offline   Reply With Quote
Old 05-21-2018, 07:12 AM   #9
I've been having issues with our "new to us" 2014 Flagstaff MAC 228 and the front bed pull. After a little of investigating I realized the one slide looks like it's missing a black piece? Assuming this piece is there to help the wheels slide easier and rest on it? I'll attach pictures. One thing I did realize is how damn hard it is to find any part information on these things! (Or maybe since I'm new I'm just unaware where I should be looking...) Does anyone have any thoughts or advice on what this part is or where the heck I can get a new one other than a Forest River/Flagstaff Dealership?
Slide out that is missing piece.
Slide out with black piece.
tcbrady is offline   Reply With Quote
Old 05-29-2018, 10:26 AM   #10
campfire joe's Avatar
A couple of my Black stripes worked their way out too. I gave up trying to put them back in. As far as i can tell not having them doesn't effect my bed from sliding in or out much. Maybe if they were all missing it would, but i doubt it. I also never found much info on what they are called or what they do.
2013 Rockwood popup 2318 g. TV 2016 acadia and a 2013 SLE Sierra p/u
campfire joe is offline   Reply With Quote
Old 05-29-2018, 10:49 AM   #11
Grammar Pedant
67L48's Avatar
The top picture (no black strip) looks an awful lot like bed rails from a classic trailer, such as my 2007 Fleetwood/Coleman. Typically, the addition of plastic like this would serve to minimize friction and maybe noise. With that said, I don't actually know the utility of those pieces of plastic.
Use a dry lubricant often on the rollers, wheels, and channels of your bed slides. Also, wipe them out occasionally with a paper towel or something. Keeping these channels clean and lubricated is always a good idea.
Old 05-29-2018, 11:03 AM   #12
ben31's Avatar
This stuff works very well for many things in a pop-up. https://smile.amazon.com/gp/product/B0081JE0OO
It contains no oil, so will not harm the fabric material.
You can use it for the slides, without worrying about it messing up your mattress, etc. I also used it on my lifts.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 05-30-2018, 03:55 PM   #13
I would use any lubricant that's dry and non-sticky.
Most silicone or graphite lubricants would do the job.
There's also this "specialized" stuff. RVcare Slide Out Silicone lube.
It's probably identical to their regular dry silicone lube, but it doesn't hurt if you want a special can of lube for your popup.
Milk_Man is offline   Reply With Quote
Old 06-01-2018, 09:18 PM   #14
I rubbed some paraffin wax on the slides and they moved a lot easier. doesn't seem to be leaving any stains or marks on the vinyl when the pop up is taken down which I was worried about with liquid type lubricants.
EJdubc is offline   Reply With Quote
bed, slide
