Old 07-13-2017, 04:34 PM   #1
Power Lift Roof, Toggle Switch Part #, 2014 Rockwood 1940LTD Pop-up Tent Trailer
Hi. First post!
My 2014 Rockwood 1940LTD popup tent trailer has the power lift roof, and the winch will come down but will not winch back up... not sure what might be causing this.
There must be power to the winch on the Down, but maybe no power on the Up? Fuse should be ok if there's power at the winch. Any ideas on what's wrong? Bad toggle switch??
Thought I may need a new toggle switch (3-pole tab). So in trying to remove the switch I accidentally broke it when unscrewing the small flat outer nut. Turns out the nut was seized on and I was actually turning the whole bolt sleeve out of the rectangular assembly, and can't get it back in due thread damage... so now I need a new toggle switch too.
How/where would I confirm the toggle switch part # for the 3-tab version for ordering in Ontario Canada? I found the applicable Powerwinch manual that notes the toggle kit Part# as R001752, but is there a generic aftermarket toggle equivalent from Digikey or Techspan switches?
If not the toggle switch, any ideas what else is going wrong? I sure hope it's not the winch...
At least we can still use a cordless drill on the manual cranking nut.
Thanks in advance.
CanadaRVGuy is offline   Reply With Quote
Old 09-04-2017, 06:35 PM   #2
Amartin453's Avatar
Did you ever get a switch and figure out the issue why the roof would not raise?
Amartin453 is offline   Reply With Quote
1940ltd, 2014, lift, power, rockwood, roo, roof, switch, tent trailer, trailer
