Old 09-14-2018, 09:47 AM   #1
FLJeepChick's Avatar
Replacing awning....
Unfortunately I lived an learned with my awning in my 2018 228bhse pup....left awning up during storm, didnt pitch it correctly and awning stretched from water and eventually bent the poles too. Need to replace the entire awning and poles. Is it best to go back to dealer or call manufacturer and get the model of the awning from them? So many options I found on online for replacement, not sure where to start.
2018 Flagstaff SE 228BHSE
2015 Jeep Wrangler Unlimited, 2.5" lift, 35" BFG KO2 Tires, 4.56 Gears
Nights camped 2018 - 6
FLJeepChick is offline   Reply With Quote
Old 09-14-2018, 09:58 AM   #2
Oaklevel's Avatar
Is it an electric or manual awning ?? Any pics. ?
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-14-2018, 10:03 AM   #3
Professional Curmudgeon
wrvond's Avatar
If you unroll the awning, the model number should be available on the fabric roller tube (FRT). If you want a direct replacement you're best bet is to contact the awning manufacturer, such as Dometic.
Be aware, the roller and arms may be manufactured by one company while the awning material could be by another company.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 09-14-2018, 10:04 AM   #4
It is manualClick image for larger version
Old 09-14-2018, 10:19 AM   #5
Originally Posted by wrvond View Post
If you unroll the awning, the model number should be available on the fabric. If you want a direct replacement you're best bet is to contact the awning manufacturer.
Be aware, the roller and arms are manufactured by one company while the awning material is by another company.
Thank you! I did not know that. I will contact Dometic
Old 09-14-2018, 12:09 PM   #6
Originally Posted by FLJeepChick View Post
It is manualAttachment 186418
Good looking popup! We ended up replacing out entire awning for the price we got quotes from Dometic on a few parts. Just keep that in mind!
tcbrady is offline   Reply With Quote
Old 09-14-2018, 01:46 PM   #7
I figured it would be pricey! Where did you replace yours from?
Old 09-14-2018, 04:01 PM   #8
There should be poles going from awning to the top of the pop up and then the support poles to the ground or to the outside like they are in the photos. Was it set up like this when it got destroyed?
Itwrx is offline   Reply With Quote
Old 09-14-2018, 04:40 PM   #9
No. This pic is from my maiden voyage with my camper before I realized how it was supposed to go up. It did not get damaged that trip. It was the next one when we had it installed the right way. I posted this pic merely to show what my awning looked like. Only pic I had.
Old 09-14-2018, 04:41 PM   #10
Had a huge rain storm and did not pitch it down on one side until it was too late and it broke
awning
