Good luck keeping it cold if you're in the sun with 80 - 90 degrees. FR installed the refrigerator wrong where there is no empty space above the refrigerator and to allow the upper vent to be installed above the refrigerator.
Therefore the heat can't get out and just collects at the top of the refrigerator enclosure.
I was only able to get 50 degrees out of the refrigerator in the 80s and that's without repeatedly opening the door to put food in or out.
I installed Titan Fans
seen in this thread and not my refrigerator works acceptably. It will now get to 30 degrees in the 90s with full sun without repeated door openings. With repeated door openings, it recovers pretty quick also but will raise up to around 40 initially.
So I found while using this refrigerator, your best bet is to keep temp controller in manual and at full fan speed, which allows quick recovery after opening and closing and adding any food or drink to the refrigerator.
2024 Black Jeep Grand Cherokee L Altitude 4WD, 121" WB, 3.6L, 8 speed, Blacked Out Package, 265/50R20 wheels, 6,200# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Go through
Indiana Dunes NP 5X/week! Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet.
