How are you progressing kingbain?
I'm in the process of fixing this exact same problem with my 2006 Rockwood Freedom 1640 (as in, I was working on it 5 min ago and came here looking for advice). I have bubbles in each of the corners, center front and near the roof vent.
My current plan, unless others have better ideas or experience is to; pump some viscus glue in from the sides using a large syringe, heat the filon (just learned what it was called from this post, thanks for that) with a heat gun to make it more pliable, and lay 50lb bags of sand on top of the trouble areas. I'll have the sides of the popup masked off to protect from excess glue being pushed out. If everything stays adhered, I plan to paint the whole roof is RustOleum Topside Marine paint.
There are some bubbles in the center that I may drill 1/8 holes in the filon to pump the glue in and patch those with JB Weld.
My questions are,
Has anyone else successfully fixed these bubbles?
What method did you use?
How does my plan sound?
Do you have good ideas as to what kind of glue to use?
Better ideas for what kind of paint to use?
I currently have the side rails, end caps and all the caulk removed.
Sorry to highjack your post and thanks in advance for any help.
8Ft box
2007 V6 RAV4
Totally new to this pop up camping thing....
