K all, need some input on the ???
roof raising issue.
Noticed that when I'm raising the roof w/the pwr winch after I have the unit leveled, that about 1/2 up thru the roof travel.....it starts to bounce /jerk up/down until it stops when it gets to the roof max height limit?
If I stop winching. It stops bouncing?
Now the bounce/jerk isn't violent.... just a little unsettling. When I do get the roof raised an in place I jam in the safety bars asap.
It's done this from day 1 when I picked it up in June.
I've greased the cable fitting underneath, oiled/lubed the lift arms - cleaned then used graphite on the winch system - no change? (
well it goes DOWN a lot smoother)
To me... something is sticking/binding a bit, causing resistance, but I'll be damned if I can find it.
That or I have a bent lift spring somewhere.
I did buy it used from a dealer who didn't have a CLUE about pop-up campers)
I will add that my old hand-cranked '96 STARCRAFT 2606 had a tendency to bounce a bit as well - AFTER I installed the A/C unit
At the time I attributed that to the small lift springs/arms and the added weight.
Now my 2014 Fleetwood w/A/C is doing the same thing. Mind you it's a much bigger roof and I am using a pwr winch
(no I haven't tried cranking it by hand)
Any thoughts?
Thanks.
