Old 09-28-2017, 11:04 AM   #1
Roof Sag repair 2007 Rockwood Freedom 1950
Recently purchased a NTU 2007 Rockwood 1950. First thing I noticed when I got it home was the roof was sagging and created a pond on the roof near the AC and Vent fan where it would slowly leak into the vent and inside the roof and pup. So my plan is to pull the vent and the AC out of the roof and then use superstrut to take the sag out. after the AC was removed the roof has about an inch and a quarter sag to it.
then on to removing the fan. It was a clamp style so four screws and a putty knife and its out
you can see where the water was leaking into the pup here
Now its time to clean things up and order the parts new fan, new AC gasket, putty tape, Self leveling sealant, unistrut, L brackets, bolts, nuts, rubber washers and white paint for the unistrut
All cleaned up! A little dawn dish soap and a scrub brush. all the parts have come in now. I just need to get some time to install the unistrut and put it all back together. More to come!....
Larry
Rainh2o is offline   Reply With Quote
Old 09-28-2017, 11:22 AM   #2
Love threads like this. I'm gonna keep up with it even though it's not something I need to worry about at the moment. I just like the process. Good job.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 09-28-2017, 12:55 PM   #3
Thanks hopefully it will turn out alright
Larry
Old 09-28-2017, 01:48 PM   #4
Just as confused as you
Scrapper's Avatar
Once the roof is repaired think about putting Eternabond on top of the seams.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 09-28-2017, 02:40 PM   #5
Do you mean on the side seams under the molding? there is no center seam on this pup? I was just planning on re caulking the side seems as there are no leaks there. Or do you mean around the base flange of the vent?
Larry
Old 09-28-2017, 03:19 PM   #6
Good job...but unlike another poster...I think it is always something we have to worry...or be concerned about.
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 09-28-2017, 06:40 PM   #7
more work
Okay so I tried my idea of building a T out of 2x4's and using a bottle jack to take out sag.(sorry the picture is sideways)
So I jacked it up with the roof down. When I get my unistrut cut to the right size I will set it on top of the T and jack it into place then I will drill the holes in the side roof boards ( I know not more holes!) to hold it against the roof
So here is what the unistrut looks like with the L bracket attached
And it seems as though it will work as you can see here with the temporary 2x4 jacked up into place. I am thinking I may put one brace in front of the AC and another one in behind it as well to keep the back from sagging
Larry
Old 09-28-2017, 06:53 PM   #8
Scrapper's Avatar
Around the flange of the vent. I don't think you could use it under the AC around the opening. They do have a double stick tape that may work. But you could ask Eternabond if they have something that will work. They have several different products.
https://www.eternabond.com/
Solution Center https://www.eternabond.com/articles.asp?id=256
Richard & Jill
Camping since 1989
Old 09-29-2017, 07:29 AM   #9
It this is reference to me all I was referring to was I am stored under a shed and my season is over for several months.
Wasn't bragging or being condescending.
Dwayne and Susan
Old 09-29-2017, 09:27 AM   #10
I had the same problem and did a similar fix. Instead of unistrut I used a sign post (think stop sign). It has a wider flange area where it contacts the roof and has holes along the bottom. Great for hanging stuff on.
cabranch47
2009 Flagstaff HW27SC (NTU 2014)
1999 Ford F150
cabranch47 is offline   Reply With Quote
Old 09-29-2017, 02:36 PM   #11
Great job fixing the roof. Looks fun.
2014 Rockwood 2516g
2011 Ram 1500 quad cab 4.7 4x4
Bhugo is offline   Reply With Quote
Old 09-29-2017, 10:58 PM   #12
Installing the supports
Okay so tonight I put in my first support. Here is what the unistrut looks like painted and ready to be installed
so I turned the L brackets the other way with the bolt holding it up inside the strut instead of under. I had to do this so I wouldn't mess up my curtain track so nothing could be lower than 2 inches.Here it is installed in the pup. I used 3/8" bolts with rubber seal washers under a flat washer on the outside and locking washers and a nut on the inside.So its kinda hard to tell what is going on in this picture but the first rail you see is the track for the door, the second rail you see is for the shower curtain, the third is the unistrut.
So as you can see its not completely flat. It turned out about the same as my test with the 2x4 and took out 1 1/4" of the sag I am think this will be enough to keep the water from ponding on the top now.
Tomorrow I will put in the second brace behind the AC and then connect the two in the center and see where that leaves me? Thats all for tonight!
Larry
Old 09-30-2017, 09:33 PM   #13
roof sag bracing
So today I put the other two unistruts in here you can see all three
here are the bolts through the sides and into the L brackets tomorrow I will post pictures of it with the AC unit back in and I will see how much the roof sags then
thats all for today I will finish it up tomorrow
Larry
Old 10-01-2017, 09:43 AM   #14
Amartin453's Avatar
Awesome thread, looking forward to see the ac unit in and if you limited the water pooling!
Question: After you installed all three braces did it close the gap more? I would of thought after the all three braces going in it would of pulled the roof tight completely taking the sag out!
Amartin453 is offline   Reply With Quote
Old 10-01-2017, 09:28 PM   #15
Sag or no Sag?
so I have the AC back in and done. I might add I bought my AC Gasket for the reinstall at Camping World and FYI thats all you get is the Gasket you don't get the little pads that I see everyone else says comes with the gasket. So the old gasket is very hard to get off but mineral sprits are your friend here! So here it is with all three braces in.
from another angle when I get done installing my new Fan-tasic vent I will get it out from under the carport and raise it up to get some better pictures of the inside.
So the final verdict did it take all the sag out? I would have to say no. It still has about an 1/8" of sag. Now I do not know what it was like when it was new I have no idea what it is suppose to be. I do know now that it will not longer have a big pool on the roof when it rains. Here is the final picture of the top with a broom stick in front of the AC unit as you can see still about an 1/8" still there. I will post a couple of final pictures when I get it out from under the carport and get it wet.Of course unless we have another hurricane and this one floods as well! I mean after all my first one I only for two weeks before it flooded hopefully this one last a little longer than that!
Larry
Old 10-02-2017, 02:41 PM   #16
Great job. You fixed it. There is always going to be a little sag. That’s about what mine is. Nice!
2014 Rockwood 2516g
Old 10-02-2017, 04:50 PM   #17
this skin roof
Oh really that's good to know I didn't know if they were perfectly flat when they left the factory or not? It really is amazing that a roof made of 1x2's , foam and a thin aluminum sheet can hold anything up at all let alone a 70 pound AC unit bouncing down the road!
Larry
Old 10-10-2017, 02:16 PM   #18
So here it is with the roof up as you can see with it painted white it just blends in with everything else going on up there already. Now we are almost ready to go camping!
Larry
Old 10-10-2017, 04:18 PM   #19
Very nice job....congrats
2011 Rockwood A122
Old 10-10-2017, 05:08 PM   #20
Awesome!
2014 Rockwood 2516g
freedom, repair, rockwood, roo, roof
