Old 08-03-2020, 03:16 PM   #1
solar panel hookup flagstaff 205
i have a flagstaff 205 with solar ready wiring. Zamp Solar is the company that forest river hi lights but i was wondering if any other portable solar panels will work for it without any other connections...
holzknecht is offline   Reply With Quote
Old 08-03-2020, 03:34 PM   #2
It is literally just some wire between the port and battery. Zamp is reverse polarity from the standard SAE connection. Adapters are plentiful online. The prep package is designed for a solar suitcase with charge controller in the suitcase.
brwarrior is offline   Reply With Quote
Old 08-03-2020, 03:52 PM   #3
I bought a ZAmp adapter online with bare wires. I then wired that to a solar charge controller, and that to a solar panel. Only the adapter is from ZAmp. It works just fine on my camper.
One word of caution. From what I understand, the ZAmp wiring is pretty small, you might want to direct-wire to the battery if installing more than a 200 watt panel. My panel is 100 and is fine but the wiring wonít handle high amperage.
Myron625 is offline   Reply With Quote
Old 08-03-2020, 04:09 PM   #4
MJKeele
Mkeele's Avatar
I have heard that the preinstalled Zamp wiring is reversed. If it's just direct cabling to the battery, can you simply swap the cables at the battery? Seems that would be easier and quicker than buying an adapter. If the colors are then backward, the wires can be labeled so you don't forget during future maintenance.
2006 Flagstaff HW 25SC
2011 Jeep Grand Cherokee
Mkeele is offline   Reply With Quote
Old 08-03-2020, 04:15 PM   #5
I just tape up the wire ends (a good 6") with the proper colored tape. Lasts longer than most labels.
Lots of times the pre-wire isn't connected at the battery but rather in a J-Box or elsewhere. This is why the simple polarity reversing adapter is so handy.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-03-2020, 05:41 PM   #6
This is what i meant. It is difficult to get the wiring wrong when it already has the correct colors on the plug.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-03-2020, 07:45 PM   #7
Campworthy's Avatar
I have a Flagstaff HW27KS with the pre-wired Zamp port. I have recently bought a Renogy 100w Solar Suitcase. The link below is the adapter I needed to plug my Renogy into the Zamp port. It's an adapter to reverse the polarity.
https://www.amazon.com/iGreely-Adapt...%2C235&sr=1-13
2018 Flagstaff HW27ks
2015 Jeep Grand Cherokee Overland
Campworthy is offline   Reply With Quote
Old 08-04-2020, 07:27 PM   #8
Tundra 2014
Solar
Very happy w/ Renergy 100 watt foldable suitcase w/ 20' extra length charge cables. Mine came w/ a 25 amp waterproof charge controller, so I can add another 100 watt panel to it. Allows me to move panel to where the sun is at and keep TT in the shade. Son-in-law does solar powered bluetooth security camera installations. Renergy panels and charge controllers is all he is using now due to their efficiency and quality. When done camping, we fold panel up in its padded case. We store on our bed in the trailer. If I was using more than a 100 panel, I would wire directly to the battery due to small wire from the ZOAR plug.
Tundra 2014 is offline   Reply With Quote
Old 08-06-2020, 11:31 AM   #9
Did you need to run any additional wires or did you just hook up that reverse adapter and it worked? How do you tell if it is charging the battery or not?
worp is offline   Reply With Quote
Old 08-06-2020, 12:54 PM   #10
I also run the renogy solar suitcase via the Zamp port on my 2280bhesp. You can get a polarity adapter for the port OR simply reverse the wires from the port as it's wired to the trailer, super simple which is what I did. Third option being using the supplied alligator clamps hooked directly to the battery.
The controller tells you everything that's going on, amp's being sent to the battery, battery voltage, amp hours generated etc. Typically I will see 5-6 amps in perfect sun via 25ft cables but have seen as high as 7 amps on a really dead battery.
2thxtrm is offline   Reply With Quote
flagstaff, solar, solar panel
