Originally Posted by kinma13
R spider bombs harmful to anything in the pup?
Occupants, pets, and anything you might later want to consume, as well as whatever you may want to consume it on or with. In other words, vacate the pup. And take with you all food, pots/pans/plates/utensils/napkins, etc. Before you resume using the pup, flush the water tank a couple of times.
Bug bombs work by allowing their chemical to seep into all the cracks and crevices. So assume everything has been tainted; wipe down the table, the sink, cutting board, etc.
But if you take those precautions, they're effective and safe. I use one in my sailboat every year to keep spiders and wasps from taking over.
Oh, and don't set off a bug bomb in a collapsed pup; set up the popup first.
