Old 02-06-2024, 12:24 PM   #21
gw1800's Avatar
Originally Posted by garywilson View Post
Length can be important. If you have ever had to put blocks under your jacks to reach the ground, go with a 30". If not an issue in the past, 24" is good. I'm basically lazy, don't like blocks, replaced all with this one and used the OEM 24" in the center:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When I had a pop up, I used the stabilizer jack like this one to change flat tires. Unhitch (keep the chain on), lower the tongue, extend the stabilizer, raise the tongue with the tongue jack, change the tire. I don't know how long or low or heavy your trailer is, but it easily worked with my Coleman.https://www.amazon.com/Dumble-Stabil...0-4513d670b6bc
30 inch jacks may work. Problem is the extra length when collapsed may cause them to stick out from the sides of the trailer. A real shin buster.
Western PA
2015 Silverado Z71
2018 toy hauler
gw1800 is offline   Reply With Quote
Old 02-06-2024, 12:49 PM   #22
Originally Posted by ER17453361 View Post
Throw the stabilizer jacks away and buy 4 screw jacks.
But I like the capability with ours, they deploy via the remote control. No bending, no grunting, no tools required, no storage space consumed. Push a button they are down, push a button and they are up. Nice!
Bob
Bob K4TAX is offline   Reply With Quote
Old 02-06-2024, 02:19 PM   #23
Bob
Same thing I used Bob. In 2010 we parked in an uneven spot in Decorah, IA. I hit the button, did the walk around 2-3 minutes later and found 2 wheels off the ground. I left it that way for the weekend. It held fine. I had the small screw jacks on a couple pop ups in the early 60's. I never had anything with stabilizers.
73
Dan/n9hqg
ER17453361 is offline   Reply With Quote
jacks, stabilizer
