Old 07-21-2017, 07:56 AM   #1
Stove mounting brackets
Good day
I am trying to locate a place (in Canada or online) where I could buy a replacement stove mounting bracket. Mine where poorly installed and one broke on our last trip.
I included a picture in case I called it wrong and you guys know the right name.
ID:	145552Click image for larger version
ID:	145553Click image for larger version
rocheleau530 is offline   Reply With Quote
Old 07-21-2017, 12:15 PM   #2
I switched mine over to a metal sink mounting bracket kit used for residential kitchen sinks. I found it at Home Depot but it is likely fairly common.
The stove on our 2514g (flip galley) kept falling out using the crappy plastic originals. I also used slightly larger diameter stainless steel screws since the originals were bent. They also came from Home Depot. The right name for the originals is 'junk'.
2016 Roo 21SS, 2016 F150
2015 Rockwood 2514G (pup), 2015 Fd Expl,
2003 Coleman Utah (pup), 2007 Fd Expl
Underthedog is offline   Reply With Quote
Old 07-21-2017, 12:16 PM   #3
Originally Posted by Underthedog View Post
I switched mine over to a metal sink mounting bracket kit used for residential sinks. I found it at Home Depot but it is likely fairly common.
Thank you sir
I will give that a try.
mount
