Old 08-30-2017, 04:49 AM   #1
NSNewbie's Avatar
Suspension spring
Hi all - we have a 2010 Rockwood Premier 2154G and we recently noticed a slight bounce that you can feel in the tv. Anyone know if this unit has leaf springs or coil springs. It's currently not in my driveway so I can't look. Also a manual reference?
NSNewbie is offline   Reply With Quote
Old 08-30-2017, 05:22 AM   #2
Rubber Torsion Axle! Youroo!!
Old 08-30-2017, 05:37 AM   #3
NSNewbie's Avatar
Could we have overloaded it?
Old 08-30-2017, 05:54 AM   #4
Yes, what is your Tow Vehicle? How many miles is on it? When was the last time the Shocks were replaced? How many #s is it rated for? Need more Info! Youroo!!
Old 08-30-2017, 06:19 AM   #5
NSNewbie's Avatar
'11 f150 but we know it's not the tv as we towed with another truck last weekend and experienced the same bounce on the trailer.
Old 08-30-2017, 06:11 PM   #6
NSNewbie's Avatar
With help from Forest River Service, we found the problem. Scalloped tire on the inside only. Figured a belt broke and likely soon to come through. Took a little investigation, so time... but minimal cost... and no roadside breakdown. Great support from Forest River.
Old 08-30-2017, 06:12 PM   #7
NSNewbie's Avatar
ID:	150144Click image for larger version
Old 09-02-2017, 06:36 AM   #8
Amartin453's Avatar
What should a good tire look like compared to a "scalloped" tire? Are the treads suppose to be straight?
Amartin453 is offline   Reply With Quote
Old 09-02-2017, 09:20 AM   #9
NSNewbie's Avatar
It had uneven wear. Only inner side of tire was worn. We then found wires coming out the inside of the tire showing that the belt was broken. Both tires ended up being that way. Cheap tires put on by the previous owner. Glad we didn't have a blowout on the Hwy.
Old 09-04-2017, 10:33 AM   #10
Trailer tires are a bit more expensive than normal car tires because they have extra side wall steel in them
Quite a bit heavier as well
If you can take the load off of them for long storage periods and protect them from UV they last 7 or 8 years of normal use according to my tire shop
stonefly is offline   Reply With Quote
suspension
