Old 05-06-2020, 10:21 PM   #1
K Withers's Avatar
Tire replacement help
New member here and this is my first post.
Wife decided she wanted to buy a popup this year. She found a 2009 Rockwood Freedom 1940LTD and just had to have it.
We've had this thing about a week and have been doing little repairs here and there. Tonight I figure I better check the tires after reading a few posts about the destruction a blown tire can cause.
Wouldn't you know... The camper is STILL ROLLING ON THE ORIGINAL TIRES! Date code 0808...
Needless to say I need to get new wheels on it before I go anywhere.
Here's where I need help. The tires on it now are on 12X4 545 rims. Tire size is a ST145/80R12 with 1220lbs load rating. Finding "name brand" tires in this size is proving difficult.
While I don't mind replacing just the tires, I wouldn't mind just getting a whole new set of wheels. I just don't know enough about wheel selection for a popup camper and what to look out for if I get different size than it came with.
K Withers is offline   Reply With Quote
Old 05-07-2020, 08:39 AM   #2
Call retailer. They will help you. You can get just tires or the tires on the rim.
https://www.etrailer.com/s.aspx?qry=Tires+and+Wheels&furl=-pg-Trailer_Tires_and_Wheels-pc-12_Inch
bondo1954 is offline   Reply With Quote
Old 05-07-2020, 08:51 AM   #3
RV There Yet?
IsleDog's Avatar
Carlisle Radial Trail RH is a fantastic tire. I replaced some on our popup with Carlisle and they rode great! they are a highly rated trailer tire. you might be able to find Maxxis as well, another great company.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 05-07-2020, 09:08 AM   #4
If you do a search for the tires that IsleDog listed, you will find a ST145/R12. It does not list the 80 (this is the height of the sidewall as a percentage of the tread width). It lists the mounted height as 21.4". As long as you are close to that, you should be good. They show them as 8 and 10 ply tires, with weight ratings of 1220 and 1520 pounds, so the 8 ply tire should fit your need.
2004 Chevy Silverado (TV)
2018 Flagstaff HW29SC
Bartonville, IL.
smither is offline   Reply With Quote
replacement, tire
