Old 11-19-2017, 12:13 PM   #1
jwh4984's Avatar
Tires off the ground
What is the consensus of keeping the trailer tires off the ground my hw277 is stored in my garage do I need to keep the tires off the ground to prevent flat spotting the tires
jwh4984 is offline   Reply With Quote
Old 11-19-2017, 12:17 PM   #2
fonzie's Avatar
I just inflate 10 psi over recommended max tire pressure rating.
Fonzie
Old 11-19-2017, 12:18 PM   #3
acadianbob's Avatar
Well, I suppose that would be ideal but I'll bet that 99.9% of RVs have their tires on the ground.
You could:
Over-inflate your tires by 10 pounds for the winter
Occasionally move your trailer a foot or two during storage
I've not ever had a problem. I store at maximum inflation +5.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 11-19-2017, 01:06 PM   #4
Kasual Kamper
I read in another thread that 1) the newer tires don't flat spot as much any more and 2) you have to be careful how you support the trailer frame as to not bend anything.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 11-19-2017, 02:57 PM   #5
jwh4984's Avatar
That's what my concern was twisting the frame
Old 11-19-2017, 04:23 PM   #6
Radial tires need not be lifted.
2014 Rockwood 2516g
2011 Ram 1500 quad cab 4.7 4x4
Bhugo is offline   Reply With Quote
Old 11-19-2017, 05:03 PM   #7
I keep my tires on the ground and on concrete. No matter what anyone says, its never created a problem for me.
KFX450RXC is offline   Reply With Quote
Old 11-20-2017, 01:50 PM   #8
ARLO
46 years with travel trailers, I've never done a damn thing. I just make sure the tires are inflated properly when I winterize the trailer and re-check them in the spring.
rlocicero is offline   Reply With Quote
Old 11-20-2017, 02:40 PM   #9
D W
D W's Avatar
"Flat Spotting" is a term associated with the old bias ply tires (non radials), of long ago. With today's steel belted radial technology the flat spot will run itself out with 10-15 revolutions on hard pavement without damage to the tire. At many dealerships and sales lots vehicles may sit for months without any detrimental effects on the tires. Now if your rig is going to sit for a year or more, then it might be advisable to block the frame with the tires off of the ground.
2016 Salem 27RKSS
D W is online now   Reply With Quote
Old 11-20-2017, 04:23 PM   #10
old40ford's Avatar
I just had a concrete pad poured today for mine. I have had tire people tell me that dirt was bad for them and to keep wood between the tire and ground. Now I won't have to do anything
Retired Auto body teacher
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 11-20-2017, 04:26 PM   #11
Novice Travel Trailer Guy
benchmarks's Avatar
I wouldnít use treated wood.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 11-20-2017, 06:59 PM   #12
Why not use treated wood?
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
johnruff is offline   Reply With Quote
Old 11-20-2017, 07:25 PM   #13
benchmarks's Avatar
On rubber chemical resistance charts it ranks "unsatisfactory".
Rubber Chemical Resistance, Rubber Chemical Compatibility, Page 2 - Mykin Inc
Old 11-20-2017, 07:36 PM   #14
The key to tires is covering them. The sun is brutal on tires. I use to carry two spares due to blowouts Iíve experienced then a light went off. Now I donít buy cheap, less expensive, tires and replace every three years or so.
Rdeejr is offline   Reply With Quote
Old 11-20-2017, 08:14 PM   #15
I wonder why the tires on my truck and wife's SUV last so long and have never been covered. We sure do not drive just at night. How many never have their wheel bearings repacked on the front of their tow vehicles and freak out if they do not repack their trailer bearings every year. Something is wrong with the way we are thinking.
Walholler is offline   Reply With Quote
Old 11-20-2017, 08:37 PM   #16
benchmarks's Avatar
So true and well said.
Old 11-20-2017, 09:40 PM   #17
NMWildcat's Avatar
Modern auto bearings are sealed. Towables bearings are not. Huge difference.
Scott and Liz - Southern NM
Old 11-20-2017, 10:36 PM   #18
Kasual Kamper
Why not?
Old 11-20-2017, 10:37 PM   #19
NMWildcat's Avatar
Originally Posted by JayArras View Post
Why not?
Cheaper? Like just about every component of RVs
Old 11-21-2017, 07:10 AM   #20
Correct. But in the older days cars and trucks had tapered roller bearings that were not sealed, just like the bearings used on most towables. We repacked them whenever the brakes were replaced, which was typically around 30,000 miles. Rarely did we see a bearing failure when it was done properly. Not sure why so many feel it necessary to clean and repack towable bearings so often.
Springerdad is offline   Reply With Quote
tire, tires
