Old 09-01-2022, 09:03 AM   #1
TV mount on outside
Hi all! With the upcoming start of the football season, I am looking at ways to mount a tv to the side of the pop up. I do have a tripod stand that I can use but I would rather use something that could be mounted to the side. My only concern is not knowing the construction on my outside walls of the '22 2318G that I have. I do have a rail for the a shelf and outside grill that is a camco product so I know this section of the wall has reinforcement but not sure about other sections. Here is what I am looking at:
https://www.etrailer.com/RV-TV-Mount...de/MR94RR.html
Has anyone come up with any creative ideas?
phil435 is offline   Reply With Quote
Old 09-01-2022, 04:41 PM   #2
My suggestion would be to make a custom mount for a holder like the one you pictures to attach to.
Perhaps two vertical bars that are bent 90 degrees at the top and the last inch or so 90 degrees again so its pointed back down. The other end of the bar you can put a pad on where it will contact the side-wall of the camper.
You could put the hooked part of the bars above the skirting of the tent at the top of the sidewall and make a couple of slots just like the ones for the bunk supports on either end to let the hooked end slip in to.
This avoids introducing new holes in to the camper body and you may even find a way to use that rig inside when your done watching outside. My preference would be to find a way to hook to the frame without making any holes. I have attached a wifi signal booster that is 12 feet tall to one of my lifter posts with neodymium magnets and a velcro strap and its been fine in wind for the last few years.
Something like my awesome microsoft Paint image is what I was describing at the top:
Name:	TV Mount.jpg
flyerdp is offline   Reply With Quote
Old 09-03-2022, 09:55 AM   #3
I like that idea. I ended using a tripod stand this weekend but I may see if I can modify it like you show in the drawing. Great idea!
mount, tv mount
