Old 10-23-2019, 07:00 PM   #21
HONDAMAN174's Avatar
Or...as long as the water is dead cold, you can just unscrew the anode without relieving pressure. The exiting water will take a lot of the sediment with it and put it on you!
Seriously though- I put the hose/water heater nozzle in there and let it build pressure then pull out and gets most of sediment out.
Just glad to get away
Old 10-23-2019, 07:32 PM   #22
Flybob's Avatar
Note that the anode rod does not screw all the way in ( to ends of thread). It is not designed to do that. Be sure to put a wrap or two of teflon tape on the threads.
Originally Posted by HappyCamperCanada View Post
I screwed it back in today as far as I could without a socket wrench. I will be investing in a socket wrench for the spring dewinterizing!
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-24-2019, 08:46 AM   #23
Trailer Park Supervisor
NJKris's Avatar
Absolutely incorrect in my experience. See post #12. My water had not been pressurized or heated in months when I nearly took an anode spear through my guts.
NJKris is offline   Reply With Quote
Old 11-05-2019, 03:09 PM   #24
VinceU's Avatar
Just a side note- if you choose tape over sealant, you must check the head of the plug to the water heater tank/frame. You will have continuity or the anode will not effectively protect the surrounding metal. Teflon easily acts as a insulator if applied incorrectly.
drain, heater, water, water heater
