Old 10-17-2019, 09:48 AM   #1
Newbie RVer
Water inputs on Rockwood Premier
Hello,
I haven't used my 2010 Rockwood Premier 2317G yet so I am still figuring out what works and where things are. I have three places where it looks like water can be filled. One is fresh water, one must be city water (next to the hot water heater) but I don't know what the other is.
ID:	217472   Click image for larger version
ID:	217473   Click image for larger version
2010 Forest River Rockwood Premier 2317G
TomInOntario is offline   Reply With Quote
Old 10-17-2019, 10:17 AM   #2
You are correct on the first two.
The third 'appears' to be something added by the previous owner.
Mounted in the middle of the vinyl graphic (the vinyl graphic would have had to been cut during application and you can't see where it was) and the long tether for the cap attaching to the latch for the top are giveaways it may not be factory.
Go inside opposite that port and see where it goes.
It's odd it has the same style filler cap as the fresh tank fill.
If you still can't figure it out, snap a picture of where that hose goes inside and post.
Some PUPS had a removable drain attachment for the sink that attached to the outside and went into a portable drain tank or bucket.
It is possible it is for one of those.
Days Camped: '17=30 '18=51 '19=58 '20=55
Old 10-17-2019, 11:53 AM   #3
Newbie RVer
Ahhh yes, good call. I will check the inside of the trailer when it's set up next season then. I assume if it's not from the factory that it's probably not as important as the other two!
Thanks.
Old 10-23-2019, 07:47 PM   #4
The third pic is the sink drain.
Looks like the 2317g floorplan was different in 2010 compared to 2019.
Here's a 2010 at a dealer, with pics.
2019 Ford F150 Race Red XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 Locking Axle, 1830# Payload, 12,700# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
Mike91 is offline   Reply With Quote
rockwood, water
