Water leak under slide out in HW277
We have a 2017 HW277 that has a water leak under the slide out. I have not been able to figure out how to look under that area. I noticed water running from under the slideout after turning on the water connection from the hookup. We have a pressure control valve. I worked around the issue by adjusting the angle of the camper so the water runs out of the outside edge instead on the floor inside the camper. How can I access the area between the floor and the bottom of the camper in the slide-out area to troubleshoot / fix the leak?
