Originally Posted by jpennington
I need help with the water and drain issue too. I'm 66, female but that did not stop me from purchasing the Rockwood 1910. I can tow it and set it up myself. However, I put the water hose from the park into the correct connection and I get water to my sink but sink does not drain. Yes, the plug is out. When it does drain, where is that water going? This plumbing is confusing me. Please, I need step by step. Purchased it used so no dealer directions.
Its usually right next to the water inlet. A bigger "cap" type screw off cover on it.
You can put one of these on it and add a hose to a catch container or grey water drain:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Adding the following:
By water inlet I mean the place you screw the water hose on to that supplies water to your sink/toilet/shower. Not the onboard water tank (assuming you have one)
I found this image from an older 1910:
