Old 10-27-2020, 04:19 PM   #21
Originally Posted by rapidly View Post
Thanks! I did that. Like everything about camper maintenance, it was a process of learning the hard way. What I now know is about a 20 minute job took good parts of a whole weekend. Required two trips to the hardware, about $30 worth of new tools, two phone conversations with the dealer, and a couple of hours searching this forum just to be able to get at the dang nut to drain the tank and then get it properly seated again.
Welcome to camper ownership. It will be a roller coaster love/hate relationship. The object is, once it is in shape, keep it that way-hopefully.
PenJoe is offline   Reply With Quote
Old 11-05-2020, 08:00 PM   #22
Probably hot and cold water shut off valves 🤔😂
2007 Ford F-350 4x4 Lariat Crew Cab 8í Box SRW 2013 3030RS
ken8246 is offline   Reply With Quote
Old 11-05-2020, 10:13 PM   #23
You didn't read any of the previous posts did you.
Greg 'n Deb
2020 R-POD 195 HRE
'17 Tacoma 3.5L,'07 Tundra 5.7L w/ tow pkgs.
Dirt Sifter is offline   Reply With Quote
Old 11-05-2020, 10:27 PM   #24
Jayhawker
Jayhawker's Avatar
Originally Posted by Mkeele View Post
Those are your water system drain valves. Also called low-point drain valves. If you run pink antifreeze in your system for winter, you would want them closed. If you just use an air compressor to blow the water out of the system, as I do, you'll want them open.
Make sure you close your low point drains after you blow them out. I forgot and left one open and mud dabbers built their nest in mine.
2018 Surveyor 243RBS
Jayhawker is offline   Reply With Quote
Old 11-06-2020, 09:04 PM   #25
Look directly under the trailer. They should run out the bottom. Low point drains so turning the valves allow the lines to drain. Just open a faucet on cold side and one on hot side.
Mandog is offline   Reply With Quote
Old 11-06-2020, 09:08 PM   #26
Mr. Dan's Avatar
None of my 4 trailers have ever had water shut off valves anywhere in them.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 11-06-2020, 09:10 PM   #27
Mr. Dan's Avatar
You don't turn these valves. See this:
Originally Posted by bikendan View Post
T-handle low point drains. Just pull up on the handle to drain. Had the same valves in my 2007 Roo hybrid.
Old 11-06-2020, 09:33 PM   #28
bikendan's Avatar
Dan, you know that many don't read previous posts! Not even mine.
Old 11-09-2020, 10:42 AM   #29
Thanks! I did that. (snip) just to be able to get at the dang nut to drain the tank and then get it properly seated again.
My RV Dealer winterized my rig the first two years I owned it and always left the anode out over the winter so that's what I do also.
flookk is offline   Reply With Quote
Old 11-09-2020, 08:47 PM   #30
Sure looks like low point drain valves.
I wish mine came with valves on the low point drains, it just came with crappy threaded on caps at the end of the pex. I took the caps off and put valves on to make it so much easier to drain the lines after camping, for sanitizing, or winterizing/dewinterizing.
All my other campers came with low point drain valves, even the pop ups. Can't believe my premier model cheapened out and used caps instead.
2019 Ford F150 Race Red XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 Locking Axle, 1830# Payload, 12,700# Tow Rating, pulling a 2020 Rockwood Premier 2716G Pop Up, with a 14' box. Previously had 2012 Jayco Jay Flight 26BH and 2008 Jayco Jay Flight 19BH Travel Trailers. Also previously had 2007 Starcraft 2406 Pop Up with 12' box and bathroom, Previously had 2005 Rockwood 2290 Pop Up with 12' box and porta potty cabinet. Trucks and Trailers.
Mike91 is offline   Reply With Quote
Old 11-09-2020, 08:49 PM   #31
Wow, I'd never leave the anode out as you now have an opening for bugs and critters to get in.
I winterize my campers myself, so I know it's done right and it pretty easy anyhow. When I dewinterize, I sanitize the water system as well.
valve
