Old 10-27-2020, 09:45 AM   #1
what are these valves?
In winterizing our new camper (used but new to us this year) I noticed these valves. The manual makes no reference to them; what are they for? This is in the lines that run to the sink. Camper is a Rockwood 2514G, model year 2015.
rapidly is offline   Reply With Quote
Old 10-27-2020, 09:48 AM   #2
Posting a picture of the valves would make it easier for people to identify them.
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 10-27-2020, 09:55 AM   #3
oops meant to, thanks. unfortunately can't find a way to do it now that it's posted, will try putting in new thread.
Old 10-27-2020, 09:58 AM   #4
photo of those valves
Old 10-27-2020, 10:07 AM   #5
I'm not familiar with your camper model, but it looks like the valves connect to pipes that go through the floor. If the pipes are open under the camper, it looks like they are low point drains to drain your water lines.
Old 10-27-2020, 10:10 AM   #6
Greywater's Avatar
I think BehindBars nailed it. They look like low point drains.
I havenít been everywhere, but itís on my list.
2021 Geo Pro G16BH
2012 Nissan Armada 4x4 Platinum
Greywater is offline   Reply With Quote
Old 10-27-2020, 10:12 AM   #7
Nearly all drains that are not identified are low point drains.
ppine is offline   Reply With Quote
Old 10-27-2020, 10:13 AM   #8
MJKeele
Mkeele's Avatar
Those are your water system drain valves. Also called low-point drain valves. If you run pink antifreeze in your system for winter, you would want them closed. If you just use an air compressor to blow the water out of the system, as I do, you'll want them open.
2006 Flagstaff HW 25SC
2011 Jeep Grand Cherokee
Mkeele is offline   Reply With Quote
Old 10-27-2020, 10:14 AM   #9
Mr. Dan's Avatar
You can edit a post within 120 minutes of posting it.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 0
Old 10-27-2020, 10:58 AM   #10
Thanks all, I'm sure you're right. I found the low point drain near the fresh water tank, didn't realize there were others.
Old 10-27-2020, 11:06 AM   #11
The drain near your fresh water tank is likely your fresh water tank drain.
The ones you posted a pic of drain all the water lines.
Iwritecode is offline   Reply With Quote
Old 10-27-2020, 01:28 PM   #12
bikendan's Avatar
T-handle low point drains. Just pull up on the handle to drain. Had the same valves in my 2007 Roo hybrid.
Old 10-27-2020, 02:14 PM   #13
Others here have answered your question.
As this may be new to you, have you located the hot water tank bi-pass valves opposite the exterior of your unit? If winterizing, the anode rod needs to be removed from the exterior side of the water heater along with reversing the positions of the tank bi-pass valves from inside. The hot water heater is drained and no antifreeze required to winterize.
PenJoe is offline   Reply With Quote
Old 10-27-2020, 02:21 PM   #14
BillyBass's Avatar
As this may be new to you, have you located the hot water tank bi-pass valves opposite the exterior of your unit? If winterizing, the cathode rod needs to be removed from the exterior side of the water heater along with reversing the positions of the tank bi-pass valves from inside. The hot water heater is drained and no antifreeze required to winterize.
And you save a lot of anti freeze
to
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 10-27-2020, 02:25 PM   #15
I'll also agree they are likely the low point drains... but.. I have also see valves like these that feed the washer/dryer combo or the space that houses the washer dryer option.
Just something else to consider if so equipped.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 10-27-2020, 02:56 PM   #16
Thanks! I did that. Like everything about camper maintenance, it was a process of learning the hard way. What I now know is about a 20 minute job took good parts of a whole weekend. Required two trips to the hardware, about $30 worth of new tools, two phone conversations with the dealer, and a couple of hours searching this forum just to be able to get at the dang nut to drain the tank and then get it properly seated again.
Old 10-27-2020, 03:22 PM   #17
I doubt if the OP have a Popup equipped with a Washer/Dryer! Youroo
Old 10-27-2020, 03:27 PM   #18
bikendan's Avatar
Ha-Ha!
Old 10-27-2020, 03:42 PM   #19
Originally Posted by bikendan View Post
Ha-Ha!
Agreed youroo... just mentioning for the sake of information if someone else was simply looking at pictures. Glad to see you back harassing us!
Old 10-27-2020, 04:04 PM   #20
GalsofEscape's Avatar
ya never know though - those highwall popups can get purty fancy.....
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
valve
