08-01-2020, 03:57 PM
What cheap outlets!
One of the 110 outlets broke in our camper. When I looked at it, I realized how cheap they are made. They could have even been broken when originally installed at the factory, just over tightening the screws would do that. I think that is what happened to at least one of the two. They don’t have a standard outlet box, it is an all-in-one design.
I replaced both standard inside outlets today with regular outlets with USB ports. I had to first enlarge the opening and install an “old work” outlet box. The back outlet was a little tricky, the wall behind the paneling is angled and I barely had the depth to fit the box.
There were GFCI stickers on the old covers but they weren’t GFCI outlets. I think they just all feed from one that is.
08-01-2020, 04:02 PM
That’s the way GFCI outlets work.
Bruce
08-01-2020, 04:20 PM
If labeled correctly they will show they are GCFI protected, that is that they are downstream of the receptacle and protected. Daisy chained if you will..
 2012 Redwood 36RL with dual awnings, 6500 Onan, Fisher Paykel Dishwasher, Splendide Combo, Goodyear G614's, Full body paint.
2015 F550 Lariat 176" wheelbase, 8' box, B&W companion
08-01-2020, 05:05 PM
GFCI outlets have a line side and a load side for wiring. Any downstream “standard” outlets wired to the load side of the GFCI outlet will be ground fault protected by the first GFCI outlet, are be labeled as such.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
08-02-2020, 10:29 AM
I know what you are talking about. I've replaced some of the outlets in my 2017 Leprechaun. If the hold down screws are tightened too much, the outlet will crack. I replaced a couple of mine with same type of outlet which are very difficult to do, and was careful when tightening. But the others I replaced with household ones. I did have to open holes a little and one of them I used a short box because of wall thickness, or lack of it.
I could not own an RV/MH if I wasn't handy, and I've done a lot to our Leprechaun, mostly upgrades though. I don’t believe in the saying, "If it ain't broke, don't fix it ". As long as I'm able, I'll continue to do all my own work, oil changes, etc. on both my MH and other vehicles.
Safe travels to all and hope this mess clears up at some point. Ron
2017 Leprechaun 311FW, Toad-2019 Ford Ranger XLT
Other toys---DW's: 1957 Chevy Nomad, '01 PT Cruiser, '08 Mustang Shelby GT. Mine: '16 Ford F150 XLT 3.5 eco, '55 Ford Gasser, '50 Ford F1, '67 Mini (full race)
08-02-2020, 11:09 AM
Location: Alberta - East of the Rockies, West of the Rest
Yeah, I replaced a few over the years with AC USB combo outlets. I don't think it makes any difference whether you have a pop up or a $$$$$ motorhome, they all use the same outlets. However, any RV is an earthquake on wheels and it may be a good idea to wrap the outlets in electrical tape before stuffing them back into the box to prevent the screws from making contact with the box and potentially causing a short or worse.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
08-02-2020, 05:15 PM
I didn’t bother with wrapping the screws. The new outlets are mounted securely in a plastic electrical box and the connections are on opposite sides of the outlet. Even if they do somehow make contact with the box, there’s nothing to short out.
08-02-2020, 05:25 PM
XLTShaker
This should be required reading for prospective owners.
" Freedom is never more than one generation away from extinction. " - Ronald Reagan
“ Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
11-27-2020, 08:22 PM
Hi, I have a 2018 Leprechaun 319MB and the bedside outlets have NO USB ports. Driving me nuts. Are you telling me that I can take a standard 110 outlet w/USB ports and install them in this camper? Sorry if that is an ignorant question. I have a GFI reset button on my bathroom outlet that "appears" to control ALL of the 110 outlets in the RV. Thank you.
11-27-2020, 08:38 PM
I would never install integrated usb outlets, for a couple of reasons:
1) USB charging standards have changed over the years - especially for phones and tablets. Is the integrated outlet going to charge at .5A? 1.2A? 2.0A? 2.1A? 3.0A? Will it support my next device?
2) Those outlets have to convert 110v AC to 5v DC, so they contain an internal transformer (just like your phone's wall wart), and it is powered up and consuming energy 100% of the time that the outlet has power.
Speaking just for myself, I'll just plug in a charger when I need one.
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
11-27-2020, 08:40 PM
I like these
just plug and go with 4 USB outlets and 6 110 AC outlets
these plug into a standard 2-plug outlet
2014 Shamrock 183
11-27-2020, 08:47 PM
Originally Posted by rsdata
I like these
44 bucks for two and they are used? (Well, they say unused, but why would the packaging be open if they haven't been used?)
-Qwkynuf
11-27-2020, 09:32 PM
If connected to shore power or on generator how much power is lost? even at 3 amp that's a max of 15 watts and won't be overloading any supply source
The big problem I see is the LACK of 5 V power at the USB charging ports when NOT connected to shore power etc.
My outlets and ports are supplied separately, 120 volt outlets from shore power, USB from 12 volt battery supply.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
11-27-2020, 10:08 PM
But that's 15 watts, 24 hours per day, 7 days per week, as long as you are plugged in. If it feels warm, it's using electricity.
I'm not in danger of chaining myself to a tree anytime soon, or laying down in front of a bulldozer - but I do like to conserve where I can. Or at least not waste on purpose.
-Qwkynuf
11-28-2020, 01:14 AM
Put an ammeter inline with the outlet sometime and look at how much (rather little) current is actually drawn when no power being used at USB port. May be surprised.
As for conservation, I replaced every light in my house with LED's and then bought a Chevy Volt. Even with charging the battery my power bill went down.
Don't worry about those small amounts, I took care of your share too
2004 Nissan Titan
11-28-2020, 11:10 AM
Trailer Park Supervisor
Ever hear of builder grade? The RV industry takes it to an extreme that's hard to match.
11-28-2020, 02:02 PM
I came to that same conclusion recently and will replace the USB outlets with plain 12V accessory outlets, where the device permits. (I have some spare 12V outlets from a previous project.)
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
11-28-2020, 02:16 PM
One of the challenges in the RV industry is that unlike residential construction where there is a minimum of 3-12" between outside sheathing and the drywall (2X4 studs) RV's can have an average of 1-1/2" of space. The general solution was to use an integrated wall box/outlet and insulation displacement connectors. And of course find the cheapest they can.
2004 Nissan Titan
