Old 09-18-2019, 10:17 AM   #21
What????
Originally Posted by cavie View Post
pop up.no battery cut off.
I know you believe that "I" understand what you think "YOU" said but I'm sure you realize that what "I" heard is not what "YOU" mean.
NO IDEA WHAT YOUR ANSWER MEANS.
campers302 is offline   Reply With Quote
Old 09-18-2019, 10:34 AM   #22
Mr. Dan's Avatar
He wasn't answering you. He was answering njfishing. See his quote?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 108; booked = 32
Old 09-19-2019, 04:44 AM   #23
My answer means that a pop up usually does not have a battery disconnect installed.
What you quoted is my signature line that has nothing tom do with this thread.
Old 09-23-2019, 06:22 PM   #24
Originally Posted by njfishing View Post
Without knowing where the wire leads, my guess would be the water pump or battery cut off...
Fresh water pump
gricardsimplycol is offline   Reply With Quote
Old 09-23-2019, 06:39 PM   #25
Water Pump Switch+
On my 2012 Forest River Flagstaff 176 Mack, that is the water pump switch. My fresh water tank has been empty. One night I keep hearing a very faint whine. Finely realized I had accidentally turned on that switch.
jackwats is offline   Reply With Quote
Old 09-23-2019, 08:05 PM   #26
If its 12 volt it's most likely the water pump if its 110 volt then water heater is most likely .
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
Old 09-23-2019, 08:28 PM   #27
It looks just like the water pump switch in my pop-up. Can you hook up to city water to test it? The pump should run as soon as you turn the tap
daggles is offline   Reply With Quote
Old 09-24-2019, 10:07 AM   #28
Mr. Dan's Avatar
You wouldn't hook up to city water to test a fresh water tank pump.
Old 09-24-2019, 10:19 AM   #29
Correct. My mistake as I was thinking of sometime else. The switch looks like it is for the fresh water tank pump. Fill the tank and then try the tank tap
Old 09-25-2019, 06:56 PM   #30
I just sold my Vicking P/U. It's your water pump switch.
Elkmontb10 is offline   Reply With Quote
switch
