Originally Posted by Larry-NC
I really think the OP (original poster) is looking for the OTHER END of the cable.
"Solar pre-wired" means they run a cable from the roof to "near" the batteries. No controller, no battery connections--just the wire from roof to battery-area.
I really think the original poster was looking for the roof-end.
I don't think there is a roof end in this case.
Looking at the Zamp connection in the frame just in front of the battery.
One leg off the back of it goes to a Ground point in the chassis.
The +ve leg goes into one of the terminals mounted on the frame under the battery tray.
Reading the brochure they seem to be for the portable Zamp kits that I guess you'd put in the ground in front of the camper rather than a fixed roof installation.
If I did install on the roof I'd put the charge controller up there and run a new wire down the roof strut to the battery.
