Old 06-03-2019, 02:10 AM   #21
Originally Posted by jimmoore13 View Post
Crawl under the trailer. View the line from the fresh tank that goes up into the body of the trailer. It will be located there. It's likely to be on the floor. It's entirely possible that it's located right behind the Converter and breaker panel.
In mine, I removed the "floor" from the cabinet above this cavity, and there it was. I had to swap my pump, and it helped a lot to remove the converter/breaker panel to give more room to work. Don't forget to unplug from shore power before working on the converter.
Good luck.
Thank you, I found it and swapped the pump out today. Everything is working great now.
MRphotography is offline   Reply With Quote
Old 06-03-2019, 04:30 AM   #22
bikendan's Avatar
you didn't say WHERE you found it.
Old 06-03-2019, 12:18 PM   #23
I found it In the least logical place you would think, mounted directly behind the fuse box underneath the pull out couch bed. I had to remove 5 screws and the support base for the couch/pullout bed in order to access the pump and all the wiring. Once it found it it was a breeze.
Old 06-03-2019, 01:58 PM   #24
bikendan's Avatar
Great, this will help others that have the same popup.
Old 06-11-2019, 06:47 AM   #25
Very clever Sir! I will do the same
Montana Rick is offline   Reply With Quote
pump
