I have a Champion 3400 Dual Fuel Inverter Generator (Model 100263). According to the manual (which you can download from their website for any model), the key statistics for this model are:
– Net Weight . . . . . . . . . . . . . . . . .95.7 lb. (43.4 kg)
– Height . . . . . . . . . . . . . . . . . . . 18.3 in. (46.4 cm)
– Width . . . . . . . . . . . . . . . . . . . . .17.3 in. (44 cm)
– Length. . . . . . . . . . . . . . . . . . . 25.1 in. (63.7 cm)
Hope this helps. By the way, I would recommend that if you store it in your pop-up that you secure it very well with ratchet-style straps over the axle so it doesn't careen around inside and damage your unit. Mine rides secured in the back of my Tundra.
Rob Payne
Hendersonville, NC
2018 Rockwood Ultra Lite 2304DS, 10K Equal-i-zer Hitch
2007 Toyota Tundra SR5 Double Cab 4WD 5.7L iForce V8
FROG Member since March 2017
