Old 11-10-2017, 05:15 PM   #1
winterizing - hot water heater question
I am winterizing our Flagstaff HW27SC for the first time today. I pulled the drain plug/anode rod from the hot water heater to drain the tank and didn't know if I should leave the anode rod out for the winter or put back in? Any advice would be appreciated! Other than that, everything went smooth.
EJdubc is offline   Reply With Quote
Old 11-10-2017, 05:25 PM   #2
Scoundrel
HangDiver's Avatar
I put mine back in. If you don't, be sure to cover the hole so nothing can crawl in.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 11-10-2017, 05:29 PM   #3
BandJCarm's Avatar
Having just done mine for the VERY FIRST TIME, I am now an expert. Thus, I say do as I did and put it back in but sort of loosely.
(Know what an expert is? An "Ex" is a has-been. A "Spert" is a drip under pressure".)
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 11-10-2017, 05:32 PM   #4
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Yeah, screw it back in loosely and rinse the tank with fresh water before the start of the next season.
Depending on how hard your water is you may want to consider filling the HWT with vinegar and let it sit overnight to dissolve mineral deposits and then thoroughly flush it out. Just don't do this with a brand new anode rod installed.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 11-10-2017, 05:40 PM   #5
Brother Les's Avatar
Tighten it back up.... if you put it in loosely... you will forget and have a mess when you fill up the water tank.... if you want to hose out the water heater next spring when it is empty... then loosen it and take it out.....
Brother Les
Old 11-10-2017, 05:43 PM   #6
BandJCarm's Avatar
That's silly, Brother Harold. I never forget anything!
FROG AR-0019-242
Old 11-10-2017, 06:02 PM   #7
From my reading of the forum for the past 5 years, I'd say it's about a 50/50 split on folks leaving it out or putting it back in. So my recommendation is: do whichever makes you feel good.
But if you leave it out, make sure to cover it so bugs don't get in, as mentioned above.
2011 Traverse LT, 3.6L, FWD
Old 11-10-2017, 06:16 PM   #8
thanks everyone - great advice! I think I will put it back in - and with my memory, better put back tight otherwise I will be sure to forget come spring!
Old 11-10-2017, 06:21 PM   #9
Put it back in and tighten it up.
You already have the tools right there from removing it so you won't need to drag them back out next spring.
I have trouble remembering what happened last week let alone last year (come spring) so why not just finish the job you started.
There are no benefits to leaving it out. It will just stick in there in mid air until the point you dewinterize and open it back up to water.
If there were any benefits to leaving it out, it would come that way from the water heater manufacturer.
Days Camped: '18=51 '19=58 '20=110 '21=21
Old 11-11-2017, 01:23 PM   #10
BobHanke's Avatar
Clean threads on tank and anode, wrap anode rod threads with new teflon tape and screw back in. If gas and electic heater, good to be sure power and breaker are both off. You can tighten anode when you change bypass valve settings next year.
BobHanke is offline   Reply With Quote
Old 11-11-2017, 01:56 PM   #11
Just as confused as you
Scrapper's Avatar
Except when you were packing up and left your DW behind at the CG.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 11-11-2017, 07:23 PM   #12
jkoenig24
You can get a plastic plug to keep dirt/critters out. Just remember to reinstall the anode rod in the spring.
jkoenig24 is offline   Reply With Quote
Old 11-11-2017, 07:47 PM   #13
Just screw it in loosely and put a tag on the outside to remind yourself.
Old 11-12-2017, 07:27 PM   #14
X2
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Wellington
jimmoore13 is offline   Reply With Quote
Old 11-12-2017, 07:33 PM   #15
That was just a suggestion, I just drain it and re-tape the anode and tighten it up.
Old 11-13-2017, 08:58 AM   #16
who is Harold? oh yes, that memory thingee, called spell check.....
Brother Les
heater, hot water, water, water heater, winter
