Furry Kid Temperature Alert
Does anybody have experience using either one of these listed below? I have narrowed it down to these two as I don't want to spend $350+ for one or get one that requires a router or a spare cell phone to be left in the coach.
This subject was brought up last year with a few suggestions. One, which I am still considering is the Temp Stick from idealsciences.com for $149 and requires no subscription and works off a wi-fi connection, cell hot spot or jet-pack. It comes with two 1.5V AA alkaline batteries. Average battery life expectancy with default settings is up to 1 year. This one has a 1 year warranty.
The other one is the Nimble N5 thru rvpetsafety.com. This one is $169 (with a $30 discount), requires a subscription which is $16.66 a month for full time or $19.99 a month as needed and be started or stopped an any time without any fees. This unit mounts to the wall and has lithium batteries that require charging every 1-2 days via the included micro usb port and adapter. This unit does not require a wi-fi connection as it's set up to work automatically with Verizon or can be used with another carrier with an additional sim card. It also has a 1 year replacement warranty.
Both send alerts via email, text or you can monitor thru an app they have available.
We would like to get one or the other before heading up to the International rally in August since we expect to be out of the RV for several hours at a time.
I have the Verizon mi-fi jet pack which has only been used once with an OK signal but no external antenna.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
